Old 12-23-2007, 12:41 PM   #1
2s4x0
2s4x0's Avatar
2s4x0 is on the path to ruin2s4x0 is on the path to ruin
Question About Swapping Ka24e To Ka24de
so i am putting the connector from the kae engine onto the kade wiring harness and i know there is suppose to be some wiring left over. does anyone know what wirings are going to be left??????
on the single cam connector i got left is
red/yellow stripe
purple/gray dots
light green/gray dots
gray/gray dots
gray/blue stripe
on wiring harnessi got left is
green/white stripe
green/black stripe
green/yellow stripe
also i have head up display n still want it to work what do u have to do? do i have to get a 91-94 guage cluster with the heads up or what?
2s4x0 is offline   Reply With Quote
Old 12-23-2007, 12:52 PM   #2
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
red/yellow stripe
purple/gray dots
gray/gray dots
gray/blue stripe
green/white stripe
green/black stripe
green/yellow stripe
i'm pretty sure u gotta get the dual cam cluster we plugged a single cam cluster in to my friends 92 and the temp gauge and the seat belt light worked and that was it and it was a good working cluster
slow40sx is offline   Reply With Quote
Old 12-23-2007, 03:31 PM   #3
projectRDM
projectRDM's Avatar
red/yellow stripe
purple/gray dots
gray/gray dots
gray/blue stripe
green/white stripe
green/black stripe
green/yellow stripe
Same wiring as doing an SR/RB, look at any writeup online.
And yes, you need a DOHC cluster, or at least the tach.
FORMERLY R240NA
Old 12-24-2007, 01:01 AM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Everything but one connector just plugs in. The connector for the dash harness is different on the dohc harenss than the sohc harness. Remove the pins from your sohc harness and transfer the wires from the dohc connector to the sohc connector that you took off your old harness. Put them in exactly the same spot as they were in the dohc harness. Plug it in, get a dohc cluster, and that's it. Pretty simple. And the connector I'm talking about is right by the main ecu connector by the way.
