Old 12-23-2007, 10:53 PM   #1
mechavore884
mechavore884's Avatar
mechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymore
SR20DE or VE?
I had heard abou tthe SR20 VE? the other day and was wondering if it was worth considering over the SR20DET (second gen blaktop?) any opinions?
mechavore884 is offline   Reply With Quote
Old 12-23-2007, 10:59 PM   #2
mechavore884
LOL.....anybody?!?!?!?
Old 12-23-2007, 10:59 PM   #3
nissolet
nissolet's Avatar
nissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-knownnissolet is making his/her stupidity well-known
its v-tech. for nissan.
nissolet is offline   Reply With Quote
Old 12-23-2007, 11:01 PM   #4
mechavore884
soo uhhh....stick with the DET hmmm do u know where I could find a VE?
Old 12-23-2007, 11:06 PM   #5
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
its not a motor stocked by most places ..u might have to call an engine source and ask them to get you one... I think its easier to play with regular de than the ve
nissan240sxkid is offline   Reply With Quote
Old 12-23-2007, 11:09 PM   #6
mechavore884
I hear roughly that most ppl recommend the VE for the naturally aspirated route? is that a bunch of sh!t
Old 12-23-2007, 11:12 PM   #7
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
if you want a VE motor...just get a S14 or S15 SR...they were the first nissan motors to use VVL...S14/S15 notchtops use a VVL intake cam to help with low and power to help battle turbo lag...the N/A versions just used the VVL cam to add a bit of umph to the torque range/power band
there is no actual RWD configuration for the SR20ve motor
Old 12-23-2007, 11:12 PM   #8
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
really its just the cams i believe that are better in the head, well and a bit different in the flow of the head lol. for the price alone for find a VE head (the vvl model) your better off just ordering some tomei cams with like a 256 lift and slapping those bad boys in there
Ca_laurier is offline   Reply With Quote
Old 12-23-2007, 11:13 PM   #9
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
for the FWD guys...the VE motors are pretty decent...they dont yield the same horesepower turnarounds that the DET motors do...but they can make a good amount of power (last time i checked...some guys were pullin 250-275 to the wheels all motor)
Old 12-23-2007, 11:14 PM   #10
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
I've been wanting to build a N/A SR using DET block, 20VE head, 16VE cams, 20DE pistons and rods and some carbs...
Would be a badass N/A set up. However unless you do some racing where raw power doesn't really mean shit then it's a waste of time.
UH the VE heads are more than just another VVL design.. They're full blown VTEC and come from the factory with solid lifters... SR16VE cam profile is 240 low/ 290 high...
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 12-23-2007, 11:16 PM   #11
mechavore884
i guess in that case its a done deal? anyone know of any lifts in NOVA? most places around here are ran by HONDAs
Old 12-23-2007, 11:19 PM   #12
Ca_laurier
Ca_laurier's Avatar
well to get a good NA motor for the price to find anything why not just run a rwd sr20de
but than again there is the whole fight over why the hell you would do it, for the power you would make for the cost you could have one hell of a sr20det. for ITB's alone on a NA setup your looking at $2500
i think everyone has wanted to build a NA rwd set up at some point, but really the question of "is it worth it" really stumps people
like i said before, to find the actual head and make i work on a rwd block your looking at more than just slapping it on
Old 12-23-2007, 11:23 PM   #13
mechavore884
lol thats what I was afraid of....cuz I've read too many articles of big name ppl trying to create N/A sr20's and failing?....imm aprolly stick with the second gen blacktop (prolly an external wastegate also)
Old 12-23-2007, 11:25 PM   #14
Ca_laurier
Ca_laurier's Avatar
its true, most guys won't get over 300 to the wheels on an na motor
the only real NA rwd motor i want is the autech s15 motor, just cause i love high compression NA motors
Old 12-24-2007, 09:32 AM   #15
PoorMans180SX
PoorMans180SX's Avatar
^^^hahahaha. 300whp NA on a DE? yeah right.
Check out www.sr20forum.com to study up on your VE. There are 2 guys on there that are in the process of building RWD VEs (FWD VE head on RWD DET block). They've been in the process for a while. It's something I've always wanted to do, but not until someone else does, hahaha.
VVL is fully variable valve timing and lift. like iVTEC, not just VTEC. So a turbo VE's power curve is quite superior to a DET's and VE's have the capability to rev higher.
Old 12-24-2007, 10:01 AM   #16
Sil80Dreams
Sil80Dreams's Avatar
Sil80Dreams is making his/her stupidity well-knownSil80Dreams is making his/her stupidity well-knownSil80Dreams is making his/her stupidity well-known
My suggestion is to go with the DET and buy the HKS Step 3 Head System and the Step 3 Cams, if it's for a daily driver get some "milder" 256/256 cams but anyway you work it that setup will enable you to rev to 9k...get that and like a GT35R and you will be making mustangs go home on your way to work in the morning lol....I haven't really read anything about the VE so my opinion probably doesn't even matter in this thread lol peace man good luck with your build.
Sil80Dreams is offline   Reply With Quote
Old 12-24-2007, 12:46 PM   #17
Koopa Troopa
Not with those cams.
Old 12-24-2007, 12:56 PM   #18
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
My buddy put a SR20VE in his NX2000, and recently turbo charged it. Was quick as shit, now kinda ridiculous for such a small car. Compression is a little high for a turbo car, but the VE head flows very well, and JWT can help out with a simple re-map of the ECU. The VE motor stock to DET stock is surprisingly not too far behind in actual race number according to some older track runs on an Autocross course local..but again this was in FWD class. Don't know if this helps? Good luck.
The Chad is offline   Reply With Quote
Old 12-24-2007, 01:07 PM   #19
nissan240sxkid
I have an s14 de full swap that I was going to give my friend for his ae86...but the ve sounds interesting might try something lol...and the solids with a 35r is sick... Tomei solids with 270s and a 35r
Old 12-24-2007, 01:52 PM   #20
PoorMans180SX
Not mine:
Old 12-24-2007, 02:23 PM   #21
Yellow4g63
I have a SR20VE in my daily driver NX2000. I love that motor to death, I plan on doing a RWD SR20+VE+T after I get done with my 240. I have a few other friends with VE's in fwd cars, The highest Revs we have seen is @ 9600rpm on the dyno and 9300ish on the street(Aftermarket valve springs in the head. H22 Crower springs are the same size). We were testing some bigger cams on the motor. I'd rather use a VE head than drop bigger cams in DE, It will drive/idle like a normal car till you hit the VVL cross over points then it's a diffrent ball game.
I bought 2 of them at the same time. 1.6 and 2.0.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 12-24-2007, 03:10 PM   #22
PoorMans180SX
^^These VE threads bring out all the sr20forum guys, hahaha.
Nice man, can't wait for the build.
Old 12-24-2007, 05:59 PM   #23
mechavore884
hahaha yeaaah I heard that....lol also kinda brings out the worst in ppl LOL (this whole rating thing is gay LOL).....
Old 12-24-2007, 06:01 PM   #24
mechavore884
i know it may seem stupid....but how much would it be to buy a VE?...any ideaas roughly?
Old 12-24-2007, 07:19 PM   #25
The Chad
The Chad's Avatar
my bud got his for $1900 back in 2001.
Old 12-24-2007, 08:03 PM   #26
Yellow4g63
I paid $1250 for the 2.0 motor and $1150 for the 1.6 motor. Then it was $300 to ship it from FL. Sometimes people sell the heads and front cover for $800ish with the 2.0 cams in there.
91 Nx2000 VVL yo
Old 12-24-2007, 08:18 PM   #27
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
My friend paid 800$ cdn for a VE motorset without ECU... It's running great in his B15 sentra...
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 12-24-2007, 10:00 PM   #28
mechavore884
this idea is gonna seem weird but do u think I'd be able to use a VE head on a DE base?!?
Old 12-24-2007, 10:37 PM   #29
HaLo
from Canada, eh!
HaLo's Avatar
it has been done in the past...
-> HaLo
Old 12-24-2007, 10:49 PM   #30
mechavore884
is it something worth putting time into?
