Old 12-26-2007, 05:47 PM   #1
sr20 driver
sr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choices
Smoke in sr motor
hey ppl marry christmas. anyways can anyone plz help me heres what happend i had a little more oil in the motor than needed. i stepped on the pedal and all the sudden all this smoke just goes everywere i stop pop the hood and my hole motor is soked in oil and know everytime when i start it white smoke comes out of the valve cover breather tube and the oil cap if i open it another words smoke gets into the motor some how and everytime i get on it my motor is soked in oil. please help make it my christmas presant. thx
sr20 driver is offline   Reply With Quote
Old 12-26-2007, 05:53 PM   #2
motorsnail
motorsnail's Avatar
motorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to all
You put the oil cap back on? Maybe blown headgasket, I dunno your description makes it sound like a fairy is spraying oil on your motor or somthing. Explain it better
motorsnail is offline   Reply With Quote
Old 12-26-2007, 05:53 PM   #3
burnsauto
burnsauto's Avatar
blown engine?
how many quarts did you put in the engine?
have you tried draining the oil, and filling it back up to the correct level?
...you may want to pay attention to basic rules of grammar next time..took me a second to realize what you were trying to explain.
Old 12-26-2007, 06:01 PM   #4
tig_tech
tig_tech's Avatar
Trader Rating: (25)
tig_tech is on a distinguished road
Feedback Score: 25 reviews
Yea too much oil will hurt the motor than too little. Your probably leaking oil past seals too. Drain that sucker and add the correct amount. Oil is cheaper than a new motor.
tig_tech is offline   Reply With Quote
Old 12-26-2007, 06:07 PM   #5
sr20 driver
the motor is in oil. i believe the oil is coming from the breather tube because if the leak was somewere lower it wouldnt be on the valve cover and it only spills when u give it load. i put 4 quarts maybe a little more. write know the oil level is good. every thing was good for about two weeks.
Old 12-26-2007, 06:11 PM   #6
WISH ONE
yeah bad things can happen, when you fill it with too much oil. damage piston rings, valve seals, o2 sensors. try and drain and refill like everyone above suggested, you might just get lucky. GL
Old 12-26-2007, 06:12 PM   #7
tig_tech
tig_tech's Avatar
Trader Rating: (25)
Ok when its on load your getting crankcase pressure (blow-by) and its exiting through the hose and into your intake or catchtank. Chech that steel fitting on the valve cover and see if its tight or not. Then check the rubber hose and make sure your clamp is tight. Thats the only possible source from everything you tried explaining.
Old 12-26-2007, 06:14 PM   #8
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
bad piston rings and/or valve seals add to blow-by gasses and oil flying through the valve cover breather tube
slothonaleash is offline   Reply With Quote
Old 12-26-2007, 06:20 PM   #9
sr20 driver
yes all the clamps are tight except that fitting its not it comes in and out. what about the white smoke were is it cominfg from
Old 12-26-2007, 06:40 PM   #10
tig_tech
tig_tech's Avatar
Trader Rating: (25)
If its white smoke then thats coolant. If you cant tell if its white or blueish then my next guess is your valve seals could be shot.
Old 12-26-2007, 06:42 PM   #11
tig_tech
tig_tech's Avatar
Trader Rating: (25)
I also think its time for you to run a leak down and compression test to find out the current condition of your engine.
Old 12-26-2007, 10:56 PM   #12
burnsauto
burnsauto's Avatar
so you mean the "t fitting" on the side of the valve cover? that shouldnt move at all.
and i dont see how the entire engine could be covered in oil by that one spot.
you may want to pop off the valve cover, take a peak to make sure nothings broken/bent/etc (like an oil squirter......ive never seen one screw up before...but you might as well check.)
Old 12-27-2007, 06:46 AM   #13
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Definitely too much oil. From the SR FAQ in this forum:
Engine Oil: (with filter change): 3 1/4 qt (3.7 L)
(w/o filter change): 3 1/8 qt (3.5 L)
Don't put in more than that, bad stuff can happen (obviously).
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 12-27-2007, 08:53 PM   #14
sr20 driver
i can tell u one thing for sure my third cylinder has no compression at all. what is it the rings?
Old 12-27-2007, 09:12 PM   #15
drifterRS
drifterRS's Avatar
drifterRS is on a distinguished road
it could be your valve seals or a bent valve or even your rings are screwed
drifterRS is offline   Reply With Quote
Old 12-28-2007, 03:00 PM   #16
sr20 driver
does anyone know what exactly might be wrong
Old 12-28-2007, 03:46 PM   #17
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
take it to a local shop,your in cali there a million that can help.
you may have a rocker arm off, does it misfire?
sillyvia13 is offline   Reply With Quote
Old 12-29-2007, 02:05 AM   #18
sr20 driver
o man tell me what it doesnt do? it does all kinds of crap idles like a fuckin tracktor. probably does misfire but i got spark everywere
