![]() Join Date: Mar 2006
PFC D-Jetro Intake Air Temp. Sensor Question
Hey all...my PFC D-Jetro just came in, and I am psyched to hook it up, but I have a question regarding the IAT sensor.
Does anyone have any good ideas on how to mount the sensor, OTHER THAN taking off the manifold? Ideally, it is supposed to be mounted on the intake manifold, which I believe involves drilling and tapping a hole for the sensor to thread into. I am concerned that doing this with the manifold on will get debris into the manifold/cylinders.... My other idea was to start drilling the hole to get the shape correct, without breaking all the way through the metal, and to do the rest with a dremmel tool with a vacuum hose near by to pick up the dust....my logic here is that the very fine dust produced by the dremmel tool on the metal wouldn't be very harmful if a tiny bit of it got inside the manifold/cylinders (??? dunno if this is that true or not) Any help would be appreciated...thanks
Daily driven |
Thanks for the idea....I was considering doing that as well, as the temperature there, near the throttle body should be essentially the same as that in the IM
Only problem there is that the surface to be drilled through is curved, and I'm not sure how good of a grab on the threads I could get, given the thinness of the steel....
Daily driven |
#5 |
Didn't say it wasn't easy, just was trying to avoid any unnecessary work.
Based on the FSM, it looks like I am just gonna pull off the upper half of the IM, and then drill a hole into one of the runners... Any advice on placement anyone??....will the tiny little sensor sticking out in one of the runners fuck up airflow significantly?? ...or would it be better to have it sticking out in the bulk collection area up top, before the air splits into the runners???
Daily driven |
#7 |
Alright, I am probably going to go on the plenum part of the IM then, since I can easily detach this from the bottom part, and probably can find a flatter surface somewhere on there.
Thanks all
Daily driven |
#9 |
Interesting.....
Did you get the sensor to tap okay into that piping....?....did you just drill it out and then buy a tap?..I was worried maybe IC piping isn't thick enough to hold the threads nicely BTW I think the thread is M10 1.25 for the IAT sensor (Mazda FD sensor), if someone could confirm that it would be beautiful
Daily driven |
