Old 10-05-2002, 01:02 AM   #1
gschroeder78
gschroeder78 is an unknown quantity at this point
Send a message via Yahoo to gschroeder78
I bought an aftermarket intake from porcarparts.com (cheap) and it didn't have a place for the air temp sensor. so I just squeezed it through the silicone hose where it connects to the MAF so it kinda just hangs in there. If the wire got shorted or too pinched that it stopped working, would that cause the engine to run richer? I've got the N1 Dual as well and I get a load of soot on the back of my car. Kinda embarassing really. People say it's normal but there's no way. Could this be the problem?
1989 240SX Coupe
-Eibach Prokit Springs
-KYB AGX Struts
-Apex-i N1 Dual Exhaust
Westminster, CO
gschroeder78 is offline   Reply With Quote
Old 10-05-2002, 11:45 AM   #2
sxtasy
Guest
Posts: n/a
I am trying to trace down the same exact problem. All the readings (voltages) seem to be ok, but the damn thing still soots up my tailpipe and pops under decell (mostly cold). I've done all the diagnosing I can think of, so the next step is just start replacing components untill the problem is cured. I have replaced the O2 sensor, and ECT sensor. Next I'm going to replace the IAT sensor.......... then the expensive MAF. And no this is not normal. If all the sensors are reading correctly the ECU should be able to compensate to get the correct fuel mixture. I'm hoping it's not the ECU as I have an expensive Stillen ECU and don't want to have to fork out the cash to repalce that! Anyway, once I get the problem corrected I'll post how things went.
Old 10-05-2002, 07:02 PM   #3
gschroeder78
Re you using a stock intake or something aftermarket? If it's aftermarket, does the sensor have somewhere to mount?
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 10-05-2002, 08:01 PM   #4
Tricky1980
Tricky1980 is an unknown quantity at this point
Send a message via AIM to Tricky1980
i have the n1 dual and an injen intake, and i have the popping under decel pretty bad, but i dont have nay black soot... so im not sure but ive had all sensors checked and i changed plugs and everything and it still does it.. so i just dunno.. unless it just thinks it needs to dump that much fuel? but when u come up with an answer let me know
Tricky1980 is offline   Reply With Quote
Old 10-05-2002, 10:20 PM   #5
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Tricky1980 @ Oct. 05 2002,8:01)</td></tr><tr><td id="QUOTE">n1 dual and an injen intake,</td></tr></table><span id='postcolor'>
Do you have a place to mount the sensor? Also is it an s13? I may just have to dup the crap intake and try something different. It never really fit right anyway.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
