Old 10-05-2002, 11:28 AM   #1
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
I have heard, for S-13's the rear rotors there is a little pin holding the rotor onto the hub....? the fronts just come off with ease.. but i'm not sure bout the rears.. does anyone have any information to help me?.. any pictures will help... thank you
-coasttek and DSC <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
CoasTek240 is offline   Reply With Quote
Old 10-05-2002, 01:29 PM   #2
SR20Fastback
SR20Fastback is an unknown quantity at this point
Send a message via AIM to SR20Fastback
I just did my calipers, rotors, and pads last week. Its really straight forward. You just take off the hanger (that holds the calipers and pads and shit in place). You remove the clips that hold the pads along with the pads, then the rotors should just slide off. Pretty much the only thing holding the rotors is the wheels... I havent done my front pads or anything, but I bet they're all about the same.
Fodive STILL blows goats, I have proof.
SR20Fastback is offline   Reply With Quote
Old 10-05-2002, 02:42 PM   #3
Tricky1980
Tricky1980 is an unknown quantity at this point
Send a message via AIM to Tricky1980
i just did all 4 of mine on a 95..... there wasnt any pins.. just the 4 bolts.. 2 holding calper to the torque holder thingy.. and the 2 holding the caliper holder around the rotoar.. just undue those bolts and the rotor slides off.. BUT, depending on where you live.. my rotoar was kinda rusted onto the hub? or whatever it is that it goes on.. so i had to go around the outer edge with rubber mallet to break it away from the rust lip.. but other than that its simple
jay
Tricky1980 is offline   Reply With Quote
Old 10-05-2002, 07:26 PM   #4
DSC
New Title
DSC is an unknown quantity at this point
Yeah, it was simple. &nbsp;I thought the rear rotor was held on by something, then I looked at it closer and it was just stuck. &nbsp;Some wd40, diet coke and a good number of hammer wacks later, they came right off. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
DSC is offline   Reply With Quote
