Old 10-05-2002, 09:55 PM   #1
dave240sx
dave240sx is an unknown quantity at this point
Send a message via Yahoo to dave240sx
symtoms:
weak clutch pedal
no pressure
So I got a new hydraulic clutch system (Master Cyl, and Slave cyl), and then it had lots of pressure, but my clutch started slipping.  So I put a new clutch in.
Now after I had the clutch put in it doesn't have that much pressure anymore and the pedal doesn't come up all the way.  It will come to where the extra play starts and stays there.
I went to auto zone because I didn't know if this was just an attribute of the hydraulic clutch or not.  The guy there said it probably needs bleeding. I'm guessing this is correct.
Also how do you bleed the clutch? Just raise the front end and pump the clutch pedal until no more bubles come up, or is there something else.
-Dave-
p.s. I just saw in the FAQ's that there is something on this but it doesn't make any sence to me since I have a brand new hydrualic system.
91 Fastback
--Pilot Shortshifter--
dave240sx is offline   Reply With Quote
Old 10-06-2002, 09:32 PM   #2
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Yeah, it definately sounds like your clutch needs to be bled. As far as how to do it, there's an article Here: http://www.motorvate.ca/auto/maxima/...utch_bleed.htm
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 10-06-2002, 10:11 PM   #3
dave240sx
Thanks man.
So after I do this all the pressure will be back too, right?
91 Fastback
