Old 01-09-2008, 08:41 PM   #1
Rusker
Rusker's Avatar
Rusker is on a distinguished road
F*CK!!! What would you do? Advice?
Removing the bolt it snapped in half. Used some vise grips to back the rest out and this is the result. Happened awhile back but I need to do something about it now. As you can see I don't have much to work with.
Drill it out, and re tap it?
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 01-09-2008, 08:45 PM   #2
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
use an extractor. can get them at any tool store
Ca_laurier is offline   Reply With Quote
Old 01-09-2008, 08:48 PM   #3
Rusker
Rusker's Avatar
Do they make one that handles hardware this small? How effective are they?
1990 S13/SR20
Old 01-09-2008, 08:50 PM   #4
Ca_laurier
Ca_laurier's Avatar
i snapped a mounting bolt for a oil pick up this week. used the one my boss has and bam was out in like 5 min
Old 01-09-2008, 08:54 PM   #5
slower than you
slower than you's Avatar
slower than you will become famous soon enoughslower than you will become famous soon enoughslower than you will become famous soon enough
Punch the center of it as a guide and try and drill it out with a small reverse drive drill bit. if you drill through it go bigger. i just did this on my exhaust manifold last week. it will spin right out with some luck. hope that helps.
slower than you is offline   Reply With Quote
Old 01-09-2008, 08:54 PM   #6
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
yea they sell easy out taps that small to take it out i had to use it on my oil pan.
Old 01-09-2008, 08:56 PM   #7
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Try going to your local hardware store and purchasing some "Easy outs" or some "Extractors"
OR IF YOU HAVE A WELDER..
Take an ordinary nut, one that's I.D. more-or-less matches the OD of the broken stud. Take your mig-welder, and set it to a high-voltage setting (I use 5). Hold the nut in your hand (don't worry, you can let go as soon as it's tacked... if you hold on too long, you'll melt your fuckin hand). Okay you've got it tacked. Now. Lay a brutal weld into it. Just fill the damn thing up with metal. Try to avoid any air-gaps... get it good and hot. The whole nut should be glowing.
Give it time to cool. Now simply un-thread the bolt you just made...Easy!
OR
step one:
you will be drilling the bolt out completely, along with the original threads. You need to determine what size the stud is, and drill it out one incriment higher than that.
so... go to the hardware store, and get some brass pipe. You want the kind with a tapered outside thread on both ends. Length doesn't really matter, get one that's a few inches long so you've got something to work with.
okay, so now you've got your brass pipe, and you've got your oversized drilled manifold stud-hole. Take a tapered-pipe-tap and tap the oversized hole the same size as the brass pipe you bought. Okay, now thread the brass pipe in NICE and hard. (the length will come into play here... you'll be turning it in with a pair of channel locks or vise-grips)
With the brass pipe threaded into the hole, take a hacksaw or a cutoff wheel and cut the pipe as close as you can to the head. Then take an abrasive-pad on your pneumatic die-grinder and grind the brass until it's ABSOLUTELY flush.
Sweet. now you've got a fresh hole with no threads. Tap the hole the correct size for your stock turbo stud, and thread it on in. BAM. done.
BTW, you are using brass rather than tapping into the aluminum because brass, like steel, has greater clamping force with smaller threads(larger number/per inch). Unlike aluminum which has greater clamping force with larger threads (smaller number/per inch)
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 01-09-2008, 08:56 PM   #8
SCato
SCato is an unknown quantity at this point
an Easy Out would get that out quick, try a tool store. you never know when you need them, but when you do they are amazing.
240Atlanta.com
SCato is offline   Reply With Quote
Old 01-09-2008, 08:58 PM   #9
CoSsilly
CoSsilly is an unknown quantity at this point
if the turbos aluminum welt a bolt to it...
easyest way
CoSsilly is offline   Reply With Quote
Old 01-09-2008, 09:02 PM   #10
rps13sr20det
rps13sr20det's Avatar
rps13sr20det is making a name for him/her selfrps13sr20det is making a name for him/her self
Tons of different ways to do it....They have already been mentioned
rps13sr20det is offline   Reply With Quote
Old 01-09-2008, 09:13 PM   #11
kikit-sideways
kikit-sideways's Avatar
kikit-sideways has a little shameless behavior in the past
s13
if u are drilling and using an extractor, make sure that the hole is straight and lined up in the center, makes things alot easier so u dont mess up the threads, same thing happened to me, worked like a champ
kikit-sideways is offline   Reply With Quote
Old 01-09-2008, 09:31 PM   #12
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
take off the housing machine it and just use a coupler.
KA-T_240 is offline   Reply With Quote
Old 01-09-2008, 09:45 PM   #13
cotbu
cotbu's Avatar
Tape over the compressor outlet, Get a punch, PB blaster, mallet(R) and a drill, Punch the center, the drill away about a mm or less. Get the flat head screwdriver place it over the bolt tap the screwdriver a couple of times to cut a groove in the bolt, unscrew with screwdriver.
drill bit should be smaller than the bolt
Old 01-09-2008, 10:10 PM   #14
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
easyest way
lol............................ msglngth
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 01-09-2008, 10:58 PM   #15
240XTC
Location: 1st amendment. Not my fault you dont like me. Does not give you the right to abuse your mod and continue your harassment in slander towards my profiles. Cowards.
240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future
^^^ down shift came up with a pretty ingenious way...nice!..but if you have no welder or your not too confident in the work that you might do on ur own, take it to the machine shop....it'll b about 10 bucks...i had mine taken off of my KA block (exhaust side)
240XTC is offline   Reply With Quote
Old 01-09-2008, 11:53 PM   #16
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Use a drill bit that is slightly smaller than the bolt diameter. Then, you can use an extractor or a left handed drill bit to get it out no problem.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-10-2008, 12:02 AM   #17
MA JasonG
MA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura about
Send a message via AIM to MA JasonG
Although extractor tools are easy to use, I've seen some people screw this up multiple times. If you feel uncomfortable using one and think you might mess up the threads just take it to a machine shop.
MA JasonG is offline   Reply With Quote
Old 01-10-2008, 03:34 AM   #18
Turtle
Turtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymore
This man knows what he speaks of... Try this!
[ame]http://youtube.com/watch?v=8Asb4RWMvig[/ame]
Turtle is offline   Reply With Quote
Old 01-10-2008, 07:44 AM   #19
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Exactly. You can go ahead and try to drill it out, but be careful. Make sure you drill the pilot hole dead center, and don't break the damn drill bit, or extractor, off in the bolt.
Because if you can't get it out yourself and you have to take it to a machine shop, it'll cost a lot more if they have to work around a broken drill bit. Don't ask how I know.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 01-10-2008, 08:14 AM   #20
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
drill it out as on-center as possible with a small drillbit, then work your way to larger drillbits one after the other, being patient and using cutting oil to keep them from breaking.
after you reach the right size drillbit you will have removed all of the bolt except for the bolts-threads that are left in the hole.
these can then be removed as one long spring-like piece of spiral steel stuff and usually will come right out easily from all of the heat generated during the drilling process.
no re-tapping required as long as you stayed on center with your drilling!
even if you have wiped out some of the threads from going off center, you will still be fine to not re-tap the hole if its an application like that where you are just looking for clamping force and the seal is made with a gasket and not the threads.
good luck.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline   Reply With Quote
Old 01-10-2008, 08:36 AM   #21
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
good luck.
That's way hard and time consuming though. Honestly, do you think if he had to ask this question, he has the tools/skills to make that happen?
Easy-out/extractor is one good idea
or just take it somewhere to get it removed, that'd be what I would do in this situation just because the headache of messing up way outweighs the cost to have someone do it
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 01-10-2008, 09:27 AM   #22
shmiddy
shmiddy's Avatar
+1 with the welding. its way better that drilling or anything like that. have a welder weld a nother peice of metal to it and screw it off. happened to me with my turbo outlet
i fully de-volved
Old 01-10-2008, 03:45 PM   #23
Rusker
Rusker's Avatar
It is true that I don't have some of the tools mentioned, but I do have the skills to get it out. I just figured someone here might have had the same problem at one time and figured I'd ask for a few ideas. I must thank everyone for the overwhelming amount of ideas.
We have a few wire fed mig welders here at work that I've done random stuff on for my cars in the past. I think I'll try welding a nut on whats left and see if that works.
Thanks guys. I'll update the thread with what worked encase anyone has the same problem in the future.
1990 S13/SR20
Old 01-10-2008, 03:58 PM   #24
300hp owen
300hp owen's Avatar
how fucking hard is it to drill a goddamn hole in a piece of metal. wtf its not like my suggestion was requiring some major mechanical skills or seriously weird tools.
hand drill.
drill bits.
done.
how does it get any easier than that?
