![]() Join Date: Mar 2007
help sparco evo 2 seat mounts
ok so i just got a sparco evo 2 seat, i mounted it in my s14 but im too tall i sit really close to the roof, im 6'1, does any one know whats the lowest seat mount, rail i can use, its a side mount seat, i have searched but i cant come up with a direct answer, thanks for your help
bride low max rail? very solid very low for most seats.
nams d lock? what kind of seat rail are you using?
fS! vlsd ! slim fans ! hid kits ! lug nuts ! http://www.zilvia.net/f/search.php?d...earchuser=bo2o ^^^click^^^ |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
If your Evo seat is anything but the basic. Meaning L, XL they wont fit on any of those mounts. I had to make mine custom, since the stock mounts are kinda side and bottom mount.
Slide Happy |
#7 |
oh forgot have the brides on other seats the nams are lower once you flip the rear seat mount bracket on the rail...thats how I got it to sit on the floor or almost I couldnt fit my pinky under it and the seat still slides
#8 |
which model of nams are you using? i found two diffrent sets, i know the evo2 is wider im just wondering if it will still bolt on to the sides
#11 |
what ever rails dont have the a cross piece that connect to each other so the seat can fit inbetween them instead of on top is the way to go and I never noticed a diff from a platform style rail...
#12 |
![]() Join Date: Dec 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
It wont fit in a bride rail by a long shot but if you want to go low you kinda need to use those rails unless you custom fab something... What I do is add tabs on the side closest to the door which mounts them wider and put the seat in. It's slightly off center but not really noticable only problem I have had is you have to move the trunk/gas door latch...
#13 | |
#15 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Those probably won't work, but not sure. I have an evo2 that I got with some bride rails, and it didn't fit (not by a long shot). Ended up having a friend make me a fixed bracket that puts the seat *right* along the cat hump...can't get any lower.
I think that's about your only option since the seat is wider than the jdm-sized seats. Alex |
#16 |
ok after searching around, and using your guys input im about to order these nagisa rails http://www.frsport.com/Nagisa-Sidemo...SX_p_3003.html any of you guys think i would have problems with the EVO2 seat?
#17 |
Take a picture of your installed seat so I can tell you what you're doing wrong..
