Old 01-12-2008, 11:04 PM   #1
farazshah
farazshah is an unknown quantity at this point
KA KA24E Carburetor Setup (Mikuni/Weber/Etc.)
So I have had a chance to do some reading and have really enjoyed the idea of a Carb'd KA24E. I have one lying around and was thinking of what I can do to get it up and running in a dual carb situation and how much it might cost me. The thing that I get hung up on is how the properly set up the distributor. I have read that you can use an older Nissan L-type distributor, with modified mounting holes, on the ka24e motor. Does anyone have any information or specific experience with carb'ing ka24e's? I would really appreciate any help with this. Ultimately, I'd like to eliminate the ECU for a really slick installation.
BTW, I have found links to the actual carbs and the intake manifold, but need some more info into the throttle linkage modifcation.
farazshah is offline   Reply With Quote
Old 01-12-2008, 11:12 PM   #2
lazy240
lazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymore
why the hell would you down grade
lazy240 is offline   Reply With Quote
Old 01-13-2008, 12:15 AM   #3
farazshah
There are a few threads out there, just read over them before you knock it. Bump back on topic.
Old 01-13-2008, 10:39 PM   #4
farazshah
bump for more information and or thoughts...
Old 01-13-2008, 10:44 PM   #5
Naim
Naim's Avatar
Naim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfection
Not necessarily.
Naim is offline   Reply With Quote
Old 01-14-2008, 10:32 AM   #6
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
b/c it yeilds more power, duh
silnismo is offline   Reply With Quote
Old 01-14-2008, 11:02 AM   #7
lazy240
it is down grading because if carburated was so much better they would have made the car like that and dont say oh what about muscle cars well ive worken on mucle cars my whole life and when you take a turn fast boom the shut off
Old 01-14-2008, 11:05 AM   #8
LongGrain
LongGrain's Avatar
carbs on KA's yield a power increase. its not downgrading...
LongGrain is offline   Reply With Quote
Old 01-14-2008, 11:10 AM   #9
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
Not really. If that happens you do not have your fuel system properly setup. I have seen TONS of carbed v-8s take HARD corners. All of the Dirt track cars around here are carbed and i have never seen one turn off in a corner.
KA-T_240 is offline   Reply With Quote
Old 01-14-2008, 11:20 AM   #10
g6civcx
g6civcx's Avatar
I have an ATL fuel cell, mechanical fuel pump, and Edelbrock carb on a Chevy 350. I hope my engine doesn't shut off when I take a 1g turn.
The factory does a lot of things for fuel economy, cost, NVH reduction, and emissions. If you don't care about those things or don't like the compromises made by the factory, there's no reason why the factory setup is better.
Old 01-14-2008, 11:21 AM   #11
murda-c
murda-c's Avatar
I had a dirtbike. I don't like jetting carbs.
MAF sensors are awesome.
Old 01-14-2008, 11:56 AM   #12
farazshah
Has anyone had any experience with carb'ing a fuel injected vehicle? I'm trying to see how to get the ignition system set up...the distributor needs to be changed to a vacuum or mechanical advance system instead of the ecu controlled distributor from what I understand as of yet.
Old 01-14-2008, 01:55 PM   #13
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
You can use a mechanical advance distributor from the L series motors but you have to also use an L series oil pump shaft that connects the distributor to the oil pump. You also have to use the distributor pedestal for the L series block. You will have to drill and tap the KA timing chain cover to mount the distributor pedestal.
allmotorKA is offline   Reply With Quote
Old 01-14-2008, 02:06 PM   #14
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
this guy did a carb/fuel injected setup on a ka24e, pretty sick build IMO.
http://home.att.net/~MabuhayCarlos/TurboIntake.html
<br>
carb setups on ka's are pretty cool in my opinion, just takes a bit of fabrication but if you have the time and money then do it
smurfgcr is offline   Reply With Quote
Old 01-15-2008, 12:41 AM   #15
LongGrain
LongGrain's Avatar
sorry to thread jack, but does anyone know if 40mm carbs are big enough to make good power on a KA24e? i found a pretty good deal on twin mikuni 40mm sidedrafts
Old 01-15-2008, 01:39 AM   #16
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
<br>
those are just itb's made from intake manifold for carbs
Red Rocket
apex is offline   Reply With Quote
Old 01-15-2008, 09:28 AM   #17
LongGrain
LongGrain's Avatar
anyone know??
Old 01-15-2008, 09:46 AM   #18
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
i know this is a z and s chassis forum, but the guys who really get into carbing ka-e are the datsun 510 guys. so if i were you, i would look into a 510 forum
cronux is offline   Reply With Quote
Old 01-15-2008, 09:51 AM   #19
burnsauto
burnsauto's Avatar
if your looking for a webber setup, try asking some oldschool toyota guys (starlets, etc.) alot of them use webber carbs, maybe you could pick up on an idea for the linkage from one of their setups.
gl
Old 01-15-2008, 12:08 PM   #20
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
That sounds like your gonna get some good power if you can fine tune those carbs. GL man keep us posted on what your going to do.
mayco_86 is offline   Reply With Quote
