Old 01-13-2008, 08:25 PM   #1
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
Fuel injector types
Alright I have a question about fuel injector options.
I searched the first four of 70+ pages using "fuel injector" as a keyword and didn't turn up much.
It's a pretty straightforward question.
What is the advantage/disadvantage to top-feed over side-feed injectors?
The reason I'm asking is because I recently obtained on an HKS anodized top-feed fuel rail. And I need to figure out whether to keep it or not. (not meaning I'm ready to install, just for future upgrades.)
Thanks in advance.
"I am not good English, I like the drift"
CHINA DRIFT
"some guys have a better relationship with their car than their wife haha. sad but true."
SECRET SOCIETY
holybushoffire is offline   Reply With Quote
Old 01-13-2008, 08:42 PM   #2
Goldeneye9mm
Goldeneye9mm's Avatar
Goldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura about
Send a message via AIM to Goldeneye9mm
well the biggest reason for top feed is the vast options and cost difference. say a 550cc injector. you could easly get both top or side feed but you have less options in side feed and you're gonna pay close to twice the price and you may only find 3 different types but in top feed you may have 30. if you have an s13 motor than keep the rail s14 sr20det's (which i unfortunatly have in this case) you have to use a different intake manifold b/c of clearance issues. so in my case i'm looking for a set of used sid feeders. thats about it.
Goldeneye9mm is offline   Reply With Quote
Old 01-13-2008, 10:52 PM   #3
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
so if I have stock s13 sr fuel rail and intake manifold, should I look for side feed or top feed? cz im thinking to get my friend's wrx's injectors
nicku is offline   Reply With Quote
Old 01-13-2008, 11:07 PM   #4
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
well if you getting your friends wrx then your decision is made.....if you go top feed injectors are cheaper but that might be offset by the price of the fittings for the rail or the rail itself if you dont have one and a fpr and lines, braided ones at least for the look....
nissan240sxkid is offline   Reply With Quote
Old 01-14-2008, 02:00 PM   #5
nicku
so you saying as long as i get the side feed, i will be fine with the stock fuel rail and fpr set up?
Old 01-14-2008, 02:39 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
its like 5 lug vs 4 lug... More options & a little cheaper...
Mechanically speaking I don't think there's much advantage to one vs the other.
MELLO*SOS is offline   Reply With Quote
