Can the mbc be used from a Z31 on a 240?
What's up guys. I installed the z32 front and rear brake set up on my 93 240. The MBC I pulled from a z32 300zx is no good. Can I use a MBC from a 89 300zx?? I was looking at a 87 300zx MBC (Same part number as a 89.) and it seems like it would work. It also uses all 3 brake line ports, unlike the z32 where you have to remove the center block off cap and install the flare looking piece in order to use the z32 MBC. I did a search and came up with nothing, but I remember reading somewhere about using the 89 MBC but I can not seem to remember where I read it. If any of you know alot about the z31 MBC, do you know if the brake fluid cup from a z32/240sx (Look the same.) would fit on the z31 MBC? Reason for asking is, I can pick up a reman. z31 MBC for 39.00. (No brake fluid cup.) while a new MBC with cup is 130.00+Thanks....
