Old 01-27-2008, 09:14 PM   #1
rob3725
rob3725's Avatar
rob3725 is a well-known jackass
SR Weird Power Loss
Runnin redtop in my s13 umm...walbro 255lph,stock injectors,blitz ecu, stock maf, z32 fuel filter. Car builds and holds bout 7-8 lbs. steady no boost leaks it just doesnt want to go from all i can figure is a must not be getting enough fuel pending checkin the pressure once i get the tools already decided to go ahead and get a nismo fpr thinkin that mine may not be working properly but if anybody knows anywhere else this problem could be im stuck if its not my fpr. INJECTORS NOT LEAKING O RINGS ARE FINE. NEW FUEL FILTER. PULLED VALVE COVER AND SET TIMING MANUALLY DEAD ON
rob3725 is offline   Reply With Quote
