Old 10-15-2002, 10:56 AM   #1
hapkido39
hapkido39 is an unknown quantity at this point
well had my canadian emisions test dont today and failed miserably especially the co reading they were 8 times the allowable level.anyone have any advice,tune up?it has new plugs maybe an o2 sensor or catalytic convertor..any help would be appreciated
hapkido39 is offline   Reply With Quote
Old 10-15-2002, 11:02 AM   #2
turbo240sx
turbo240sx is an unknown quantity at this point
mine failed too "s-13" i had a gutted cat and had it running real rich. i leaned out the TPS sensor"throttle position sensor"
to .38 and retarted timing,5 degrees and alot of dry gas. passed with flying colors. hope this helps. oh yeah let the car run hot dont turno on the heat, the hotter it runs the cleaner the pipe sniffer see's
240sx s-13 TURBO weekend v-8 killer
90 Talon TSI
WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY.
turbo240sx is offline   Reply With Quote
Old 10-15-2002, 12:06 PM   #3
240sxtreme
240sxtreme is an unknown quantity at this point
Send a message via Yahoo to 240sxtreme
my 92 didn't pass this last time either, the numbers where way too high...took it to my mechanics, had them run diagnostics, they put a new cat on, and all the numbers dropped by almost 1/2.
A good cat is probably the best thing for emissions.
I suggest doing what I do, run with 1 cat, and 1 in storage somewhere...when it comes time to doing emissions, put the cat you had in storage on...since it's barely used....it'll pass with flying colors..afterwards, go and switch cats again.  You'll always pass this way....unless your engine is really running like crap.
240sxtreme is offline   Reply With Quote
Old 10-15-2002, 01:37 PM   #4
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Move somewhere that doesn't have emissions. . .
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 10-15-2002, 02:06 PM   #5
AKADriver
AKADriver's Avatar
High CO is typically caused by a rich condition, how was your HC reading? &nbsp;Close to the limit? &nbsp;Ideally you want low numbers for all three (like my car&#33<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>. &nbsp;Yeah having no tests would be nice, but hey, consider it a clue that your car needs some maintenance. &nbsp;A car that's running right should never fail unless it's heavily modified.
Did it fail at idle or at speed?
Try the basics first. &nbsp;Clean the MAF and AIV. &nbsp;Check your idle speed (IAA valve) if it's idle where you failed.
Old 10-15-2002, 03:21 PM   #6
hapkido39
It passed at idle and failed at speed miserably especially the co the rest of the readings were close
