Old 02-11-2008, 10:15 AM   #1
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
sr20 compression test results
So yeaaaaa out of sheer boredom at work i decided to do a compression test on my motor and this is what i came up with:
Engine is moderatly warm.
CLY1=105psi
CYL2=105psi
CYL3=104psi
CYL4=103psi
When i searched for compression test results i saw people coming up with 140psi numbers and new SR motors should be around 200psi...this blew me away, i didnt think that compression numbers were supposed to be that high. Should i pull the head and check her out?? This is a stock sr with stock boost, stock cams just the normal bolt ons, FMIC, Tubular mani, exhaust. Thanks guys
d-faction.com
Landers is offline   Reply With Quote
Old 02-11-2008, 10:59 AM   #2
DirtyS14
DirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enough
What is your elevation?
Put a teaspoon of motor oil in a cylinder and test it. If the compression goes up its most likely your rings. If it doesn't go up then it could be a headgasket issue or valves seals etc etc.
DirtyS14 is offline   Reply With Quote
Old 02-11-2008, 11:35 AM   #3
Landers
Elevation is about 500ft nothing that would effect that. The power hasn't felt weak or anything i just did this compression test out of randomness. The motor has never been refreshed to my knowledge, it should have stock pistons and such.
d-faction.com
Old 02-11-2008, 11:37 AM   #4
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
warm your engine to normal operating temps and test it again. You should have more normal numbers. Also make sure you test with the throttle body open. You should be getting number around 150-155.
garagelu is offline   Reply With Quote
Old 02-11-2008, 11:45 AM   #5
tig_tech
tig_tech's Avatar
Trader Rating: (25)
tig_tech is on a distinguished road
Feedback Score: 25 reviews
Also,crank it enough until the gauge stabilizes the highest reading. I would also leak down your motor as well.
tig_tech is offline   Reply With Quote
Old 02-11-2008, 12:12 PM   #6
bestos02
bestos02 is an unknown quantity at this point
my experience has been that EVEN numbers across the board like you have got - are good news.
i did a test on one of my VW 1.8t last year. with 2 different air devices. first run i was seeing 135-140s acrooss the board,
the 2nd run, 2 days later, i was seeing 180s across the board, different measuring device (probably better) and different day.
gotta be a warm motor, just be slow taking out the spark plugs, warm threads are tender.
bestos02 is offline   Reply With Quote
Old 02-11-2008, 12:25 PM   #7
S14DB
AFC #1
S14DB's Avatar
You have cams or stock? TB held open?
Old 02-12-2008, 06:56 AM   #8
Landers
throttle body open, yes i let it stabalize i let it crank over about 5 times and the gauge maxed out after about 3 cranks. When i did the test when the motor was hot it came out to 98-95psi numbers. Stock cams. I think im gonna do a leakdown sometime this week. thanks guys
d-faction.com
Old 03-26-2008, 10:37 AM   #9
khoadogg
khoadogg's Avatar
khoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of light
Send a message via AIM to khoadogg
so wat were the leakdown results? I"m in the same process with my honda motor.
AIM SoarinStrong[B]STRONG 6iX[B]
RB single turbo ///Work AMKREAD 180sx
khoadogg is offline   Reply With Quote
Old 03-26-2008, 10:43 AM   #10
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
isnt it you need to crank the motor 3 times at most by FSM?
Old 03-26-2008, 10:49 AM   #11
adictd2b00st
adictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to behold
Send a message via AIM to adictd2b00st
You really shouldn't have to crank it more than 3-4 times
adictd2b00st is offline   Reply With Quote
Old 03-26-2008, 06:40 PM   #12
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
4 times should be max. on my first sr, i got 150 in the first 3 and 155 in the last. on my current motor, i'm too scared to do a test. its running fine and i don't wanna start getting all paranoid
slideways2004 is offline   Reply With Quote
