Old 02-11-2008, 05:54 PM   #1
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
SR20DET helppp
K, I just finished swapping in my redtop. I have spark, fuel, and she starts right up.
Now here's the problem. When I start it up, it immediately revs to 2000RPMs and stay for a few seconds before jumping to 4000RPMs. I kinda get scared and turn the car off before it gets any higher than that. ECU was throwing a code 34 which is the knock sensor. Turned out that it was bad gas and tons of rust in the tank. So I got that fixed. No rust in the tank and fresh 93, code 55, but the problem is still there. It smells like the car is running really rich. I'm not sure of the condition of the turbo. Could a bad turbo cause the RPMs to just go up.
flip3d is offline   Reply With Quote
Old 02-11-2008, 06:54 PM   #2
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
What have you checked out so far?
I would probably start with the idle adjustement screw located on the throttle body. I picked up a 90 SOHC a while back that needed a timing chain. When I finally put everything back together, I had the same problem. I tried trouble shooting the problem for about 2 weeks and found that the retard that had the car before me, had replaced the small screw with a larger one and had screwed that bad boy in. Apparently, he was trying to avoid any timing chain rattle by setting the idle higher.
Also, check TPS and MAF.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 02-11-2008, 06:57 PM   #3
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
check your IACV and adjust it. if that doesnt work check your maf.
180sx_Drifter is offline   Reply With Quote
Old 02-11-2008, 09:10 PM   #4
flip3d
flip3d's Avatar
I havent really messed with the IACV yet but I have a brand new Z32 MAF. So I guess I'll switch the TPS and play with the IACV tomorrow and let you guys know.
I just find it strange how it just revs up to 4000+RPMs. It sits at 2000 for 10 seconds then all of a sudden the RPMS shoot up like its at WOT.
Old 02-12-2008, 12:29 PM   #5
flip3d
flip3d's Avatar
Swapped the throttle body and turned the screw on the IACV. It idles around 1200-1500RPM and it doesnt rev on its own but now it backfires like a bitch and the throttle isnt very responsive. Also, It flashed code 11 but it went away.
Any ideas?
Old 02-12-2008, 01:47 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You using anything to convert the signal for that Z-maf? Do the usual stuff, adjust your IACV, double check timing, do a boost leak test...
CLICK HERE!!!
Old 02-12-2008, 01:56 PM   #7
turboboost12004
turboboost12004's Avatar
turboboost12004 is an unknown quantity at this point
sounds like it could be vacumm leak...but idk....aicv...what about timing..check that also
Sieze the day or Die regreting the time you lost
turboboost12004 is offline   Reply With Quote
