Old 02-12-2008, 02:21 AM   #1
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
Clutch not fully disengaging problem @5500 rpm
First here are the info
Spec stage 3 6puck clutch
2000 miles
ka24de
Brand new oem Slave/ Master/ SS clutch line/removed damper box
So the problem i have is It isnt fully disengauging when in GEAR
So in when in gear/and clutch pedal is pressed, i rev to 5500rpm and i feel the car wanting to launch foward, and a nasty grind sounds.
Before i got a new slave/master/ss line/damper box removal
it would do it at ~3100 rpm and only when i drove the car around a bit(would not do it cold)
Now it just does it all the time but at 5500rpm
Any ideas?
BTW
my clutch master Fork is adjusted all the way out(longest it can go) is this correct?it was like this on the oem master i removed so i followed it
Here is a video back when it did it at ~3100rpm
hard to hear but if u lisen carefully u can hear it grind
[ame]http://youtube.com/watch?v=trT3yzAg5xY[/ame]
importdude is offline   Reply With Quote
Old 02-12-2008, 02:26 AM   #2
picho
picho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond reputepicho has a reputation beyond repute
sonds like tranny problem bro synchros mayb
picho is offline   Reply With Quote
Old 02-12-2008, 02:44 AM   #3
S14DB
AFC #1
S14DB's Avatar
You replace the Input Bushing? Grease the input shaft? Break in properly?
But, it sounds like your tranny is trashed. Cause I would expect some shifter movement and the car wanting to lerch and stall out like someone that doesn't know how to drive stick. Yours just makes god awful sounds.
Old 02-12-2008, 02:36 PM   #4
importdude
importdude's Avatar
dam it
really stumped
Old 02-12-2008, 02:38 PM   #5
steve shadows
steve shadows's Avatar
Did you over-torque the pressure plate bolts?
Is it hard to get into gear sometimes when depressed?
Or get out of gear?
They are only supposed to be torque to 36 ft lbs iirc
Like Me on FaceBook !
Old 02-12-2008, 03:57 PM   #6
importdude
importdude's Avatar
Never HARD into gear
my Test's are at Standstill/idle
Everything drives normal
cept shifting anything over 5500rpm
