Old 02-13-2008, 02:16 PM   #1
Driftapparel.com
Driftapparel.com's Avatar
Driftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura about
SR Temp Rises when heater is on!
Everytime I turn the heater the temperature SEEMS to be rising.
Anyone heard of this before? The stock gauge doesnt seem to change at all but the Blitz FATT reads that the temp is rising. I usually let it get to about 30 celsius and turn the heat off! Then the FATT temp starts to go down again!
I'm not sure if its just effecting the FATT or the engine temp is actually rising.
Driftapparel.com is offline   Reply With Quote
Old 02-13-2008, 02:20 PM   #2
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Where is your FATT sensor located?
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 02-13-2008, 02:21 PM   #3
kdashy
kdashy's Avatar
kdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfection
Send a message via AIM to kdashy
Uh, 30 celcius? isn't that like 85 degrees?
Water temp goes way higher than that.
kdashy is offline   Reply With Quote
Old 02-13-2008, 02:24 PM   #4
Driftapparel.com
hmmm. maybe not. the temp on the FATT usually sits around 17-25 whatever the FATT measures the temp in lol! so im not entirely sure kdashy.
And I have no idea where the sensor is ill have to check. but that might make a difference huh? thanks dutchmalmiss
Old 02-13-2008, 02:28 PM   #5
kdashy
kdashy's Avatar
The temp sensor is probably sitting in your cabin somewhere and measuring ambient temp.
Water temp needs to be 76C/170F just for the thermostat to open and considered normal operating temp.
Old 02-13-2008, 02:29 PM   #6
Sileighty_85
Sileighty_85's Avatar
If your FATT reads Water Temp in celcius, and only reading 30 Deg. Somthings wrong I got Defi's and mine read 80ish on a hot day
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-13-2008, 02:32 PM   #7
Driftapparel.com
Wow thanks alot guys! so it probably is not a problem then? lol that would be hilarious!
Is it possible that any of you might know something about my leaky H2O line post. I'll bump it.
Thanks again!
