Old 10-20-2002, 03:34 PM   #1
ny180sx
ny180sx is an unknown quantity at this point
I bought the BOSCH Fuel filter and I'm changing filter myself.
the the book says that if my car has Fuel Injector system [EFI] then I have release fuel pressure before i change this filter..
I have a 1990' 240sx..w/KA24E.  Does my car has EFI System? and do I have to release the fuel pressure??
Anyone has experience with this situation??
Thanks..
ny180sx is offline   Reply With Quote
Old 10-20-2002, 04:14 PM   #2
s14 RL
s14 RL is an unknown quantity at this point
Send a message via AIM to s14 RL
Theres a writeup at 240sx.org along with a bunch of other helpful answers to faqs for other common maintenance, etc.
http://www.240sx.org/faq/articles/fu...eplacement.htm
s14 RL is offline   Reply With Quote
Old 10-20-2002, 05:42 PM   #3
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
yes, the 90 240sx is EFI. To release gas pressure, twist your gas cap off (you'll hear the pressure hiss). You can put it back in or leave it off it doesn't matter. Then, find your fuel filter. Loosen the upper rubber line and pull it off, some fuel will spill, that can't be prevented. Tuck the line away and do the same to the bottom line. Install is reverse of removal, make sure both lines are connected and tightened, and make sure fuel filter is secure.
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 10-20-2002, 06:35 PM   #4
fodive
fodive's Avatar
fodive is an unknown quantity at this point
simple, it is. it takes no longer than 5 minutes, jsut dont expect any power gains or anything
roots.
fodive is offline   Reply With Quote
Old 10-20-2002, 07:47 PM   #5
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (anthony240 @ Oct. 21 2002,06:42)</td></tr><tr><td id="QUOTE">yes, the 90 240sx is EFI. To release gas pressure, twist your gas cap off (you'll hear the pressure hiss). You can put it back in or leave it off it doesn't matter. Then, find your fuel filter. Loosen the upper rubber line and pull it off, some fuel will spill, that can't be prevented. Tuck the line away and do the same to the bottom line. Install is reverse of removal, make sure both lines are connected and tightened, and make sure fuel filter is secure.</td></tr></table><span id='postcolor'>
that does not fully release the pressure. you need to remove the fuel pump relay or fuse depends on your car i think s13's have relays.
once you remove it start the car and it will die out. try starting it till nothing happens at all, that is when fp is completely relieved.
but i never release the pressure when i changed fuel filters, you just have to be extra careful. this was me and im use to it and have done it over 100 times so if you are not comfortable nor have you done it before i don't recommend doing that.
edit* also when you put the new filter on put soe lube (white lith or red grease) on the tips so next time you change the filter it will come of with ease <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 10-20-2002, 08:09 PM   #6
camppain
camppain's Avatar
here is what i typed up for dsc topic but i guess he deleted it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
figured i would include it in here
1.release fuel pressure by removing fuel pump relay or fuse (your car should have one or the other either in engine bay or in kick panel) and fuel cap
2. start car (it should turn on and run for a few seconds then sputter and die out) try starting the car a few more times to make sure there is no fuel
3. remove fuel filter from clip(retainer whatever you want to all it) unscrew the clamps and move them out of the way.
4 you can (at times) just twist and pull off the rubber hoses or you will need some needle nose or hose remover (dont know the exact name of it but i got one from snap on)
5. remove the top one and put it to the side and make sure it does not drip point it upwards and away from eyesight (also remeber to be cautious while doing this in case you did not remove fuel pressure because fuel may spray you in your eye trust me on this one)
6 grab filter and lower hose and twist and tug. if it does not work use the tools mentioned in step 4
7. put some white lith or red grease (at least some lubricating source) on the ends that go in the hoses to make the next time you replace your fuel filter a much easier expierience
do not worry and think the hoses can come off this way with the grease.
to install just reverse the order
