![]() Join Date: Sep 2006
SR20det-Ground strap on back- SPARKING!
So my car wasnt starting for some odd reason... but while looking in the engine bay during cranking I noticed a spark! On the back of the block, on the head theres a factory small braided stainless wire bolted on, and a connector at the other end. Its kinda by where all the coil packs ground. I had my friend hold it to ground while I cranked it...and it burnt him and started smoking. WTF! that much power from a ground/....
So is the head not grounded correctly? If i attach it to ground i am afraid it will start smoking again. My block is gorunded with 4gauge wire from the starter bolt right to frame..with a good ground. Should I reground the head??? anytone had this problem? Do I have a short? |
![]() Join Date: May 2006
LMAO i cant help it but you burnt your buddy hahahahaha lol
ok yes you should ground the head but ground it properly and make if you ground the wiring shave a little paint off where you are grounding it so that its grounded right. o yea check your grounding to your starter. sometimes its loose cause mine happens to be like that sometimes so i check it often enough. and reground it.
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
![]() Join Date: Jan 2007
bad connections make sparks, and make heat
fix yo grounds son! also make sure the plastic alternator grommet isn't cracked/broken. it's the little piece of plastic that separates the charge stud from the alternator housing (which is grounded to your motor by all the bracketry etc.) jiggle your charge wire. and i concur with add more grounds. from the battery to the chassis and chassis to motor. Dave =]
