I drive a European S14 which has a SR20DET and I've been having problems with my idle. Tonight I have taken a closer look to come up with a better description of the problem.
Here's what I've come up with: The engine is already warm and it idles at 800rpm. But after a half a minute or so the idle will drop to about 600rpm, at which point the exhaust will spew out some dark smoke. This drop in rpm will last about 5 seconds, after which the idle will climb back up to 800rpm with no visible (colored) smoke at all. And the cycle repeats itself. What could be the problem? I just hope it won't be too expensive to fix.
1995 (Euro-spec) s14, perpetual moneypit |
What type of BOV do you have? Sounds like a classic case of atmospheric BOV staying a little open.
Jed <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/devil.gif" border="0" valign="absmiddle" alt=':devil:'> |
I have an HKS SSQV... I've had it for about a year now and didn't start having problems until about 3 months ago. But I'll try adjusting the screw of the BOV...
Could it be that the lambda sensor is faulty? Or some kind of blown gasket?
Maybe a small boost leak, however you would also notice that a lot more. You'd have different problems also.
If you 02 sensor was bad you'd run rich however I doubt that you would be having those idle problems. How is it driving wise? For quicker response email me at [email protected] Jed <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/devil.gif" border="0" valign="absmiddle" alt=':devil:'> |
