Old 02-22-2008, 05:45 PM   #1
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
Just put a new battery in and noticed..
This.. ( It was under the right nut before i switched batteries out)
I know its suppose to go under the right nut pictured but is it suppose to look like this or is it suppose to make a complete circle?
Mangudai is offline   Reply With Quote
Old 02-22-2008, 05:49 PM   #2
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
if your talking about the harness/clip next to the terminal then yes, the little piece that is left there should be a whole circle so that you can attach it to the nut on the terminal...
boogerlovers is offline   Reply With Quote
Old 02-22-2008, 05:52 PM   #3
Mangudai
Mangudai's Avatar
Smh thats what I thought. Is this something I could get in a discount parts store or do I have to specifically buy?
Old 02-22-2008, 05:53 PM   #4
Onitsukagirl
Onitsukagirl's Avatar
Onitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really nice
lol... cute, sorry I had to laugh "I know its suppose to go under the right nut pictured but is it suppose to look like this or is it suppose to make a complete circle?" cute. I had one break on mine before and I just got a new looking one from an S14 in a junkyard.
Onitsukagirl is offline   Reply With Quote
Old 02-22-2008, 05:54 PM   #5
lazy240
lazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymorelazy240 is not welcome here anymore
you could buy that prob anywhere
lazy240 is offline   Reply With Quote
Old 02-22-2008, 07:56 PM   #6
Mangudai
Mangudai's Avatar
What is it called?
Old 02-22-2008, 07:57 PM   #7
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
I call it wire strippers and a ring terminal.
Tenchuu is offline   Reply With Quote
Old 02-23-2008, 01:23 AM   #8
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Solder something useful to it. That piece is important. Runs all your ignition/etc.
Deftec is offline   Reply With Quote
Old 02-23-2008, 03:21 AM   #9
Mangudai
Mangudai's Avatar
Thanks guys. I'll have at it tomorrow per these instructions http://www.kampenwagen.co.uk/Crimping.htm
Let you know how it goes.
Old 02-23-2008, 02:43 PM   #10
Mangudai
Mangudai's Avatar
Anyone know which # ring terminal I should purchase? The fsm doesn't say anything about ring terminals.
Old 02-23-2008, 03:51 PM   #11
Tops*
Tops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfection
As long as the nut fits through the ring and you have a good solid connection, you're golden.
MADE IN JAPAN
Tops* is offline   Reply With Quote
Old 02-23-2008, 04:15 PM   #12
Mangudai
Mangudai's Avatar
True that. I inspected more today and it looks a little different than it does on other cars. I'm going to try and hit a junkyard up tomorrow for another one.
Old 02-24-2008, 01:51 AM   #13
!Zar!
!Zar!'s Avatar
That goes to your alternator... So I suggest you don't drive your car without that being connected.
Old 02-24-2008, 08:16 AM   #14
projectRDM
projectRDM's Avatar
More than that. Right now the only thing connected to your battery is the starter feed. Everything else is dead. Go buy two 8-10ga ring terminals, crimp them on those wires, and bolt it all down. Shouldn't take more than a minute to fix.
FORMERLY R240NA
Old 02-24-2008, 08:48 AM   #15
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
wow so you basically just crank the car drive for the most part huh
bigOdom1 is offline   Reply With Quote
Old 02-24-2008, 12:56 PM   #16
Mangudai
Mangudai's Avatar
No, its wedged under the bolt pretty good. But not good enough to just leave like that.
Old 02-24-2008, 01:26 PM   #17
jackjack
jackjack's Avatar
mine broke as well. wire strippers, ring terminal, done.
Old 02-29-2008, 04:45 PM   #18
Mangudai
Mangudai's Avatar
I bought some ring terminals and a wire stripper but im unsure about how to put them on. The ring terminal on the car is molded into the plastic on the clip. Im assuming im suppose to..cut these two wires connected to the clip and crimp a terminal to them?
Old 02-29-2008, 04:55 PM   #19
jackjack
jackjack's Avatar
^ yes sir. you are correct.
Old 02-29-2008, 05:00 PM   #20
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
thread jack...sorry, just a quick question....i bought a shell and i put a motor in it and i cant find the ring terminal anywhere in the harness(only harness that came from this shell is the BIG one that goes across rad support, all the others i put in off my parts car). Its supposed to be right near that main fuse box where the OE battery placement is. On this car the battery is mounted in the trunk and no ring terminals to be found....anyone care to help? I just need to know where to run power into that box. do i power the 75a alt fuse?
d-faction.com
Landers is offline   Reply With Quote
Old 02-29-2008, 06:03 PM   #21
Mangudai
Mangudai's Avatar
Thanks for the reply
Old 03-01-2008, 11:10 AM   #22
Mangudai
Mangudai's Avatar
Pic came out crappy but thanks a lot guys. Just got it done.
Old 03-02-2008, 10:28 PM   #23
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
i cant believe there was honestly a thread about this, altho im glad the op figured it out. guess ya gotta start somewhere...
theslows13 is offline   Reply With Quote
