Old 02-24-2008, 03:09 PM   #1
cutter
cutter is on the path to ruincutter is on the path to ruin
Send a message via AIM to cutter
built engine and big boy turbo kit
red top
86.5 mm bore 9-1 compression
weisco pistons with coated skirts. all pistons were balanced to 1/1000 of a gram-$350
tomei h beam rods with arp l19 rod bolts-rated to 800 hp. also balanced to 1/1000 of a gram-$1100 (look them up on spl)
acl coated race bearings-$250
micro polished and balanced crank.
block was bored with a torque plate- (torque plate rental was $125)
block was honed at operating temperature
balanced as a complete rotating assembly with crank pulley, flywheel and clutch. these pieces were also balanced individually.
new oil pump/water pump/timing chain assembly.($350)
arp main studs-$100
the bigger arp head studs-$120
commetic gasket-$100
total parts-2495
head- full race port-
brian crower stage 3 cams- $300
greddy ras- $80
jwt valve guides-$100
jwt valve seals-$50
supertech dual valve springs &
super tech titanium spring seats and retainers- $350
full radius valve job. flows more than any 3/4/5* valve job.
valves and head were cut with a carbide cutter, not stones.
custom lifter setup,- $200 the head can rev to 9200 rpm, i have only taken it to 8500 because i do not want my piston speeds to exceed 25 meters per second. the setup is still hydraulic so no adjustment is needed.
grand total on parts-$3575
the machine work was done at Calvert precision engines in denton texas. he builds mostly pro mod motors, but he has done many import engines that made alot of power and are daily driven. like an 800hp 300zx that has been daily driven for 3 years.
machine work and assembly was $1700
stock sr20det long block was $1200
grand total- $6475
the motor right now has about 3000 miles on it. its broken in and never been beat on. i did take it to the dyno with a very conservative tune (11* of timing up top, and 11-1 afr) letting off at 7k rpm at 17-18lbs of boost it made 355 whp and 273 ftlbs of torque. if i would have gone to 8500 who knows what it would have made.it was a 3rd gear pull. most people do 4th gear pulls because it usually shows more power. thats what the dyno guy said. i built this motor to handle 500hp and that is easily attainable with a little more timing, boost and race gas.
buy this and save a couple thousand dollars, and a couple months of time.
asking $4200 plus shipping
hybridynamics equal length manifold. all stainless. excellent quality. collector is beautiful. similar to a full race manifold. t3 flanged and uses a tial 44mm. great shape only 2500 miles on it. no cracks. perfect. $740
precision sc60 turbo. to4s compressor housing, rated to 580 hp. fully spooled around 48-4900 rpm, only has 4000 miles on it. $575
tial 44mm silver cap with a 15 lb spring- 2500 miles $300
the turbo was used on my last fwd sr. i went to rwd. excellent turbo for anyone seeking 500 whp. if some one buys the whole kit i will throw in oil feed and drain fittings and lines. i will trade for a gt2871r,
chris 903 530 9214
pics of the manifold will be up soon
cutter is offline   Reply With Quote
Old 02-25-2008, 03:13 PM   #2
cutter
Old 02-25-2008, 03:49 PM   #3
cutter
dang quality, low mileage used parts. whats wrong no offers?
Old 02-25-2008, 04:39 PM   #4
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
u selling the intake manifold also? greddy or knock off? pm me price if u selling it please
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 02-25-2008, 05:23 PM   #5
turbodreams954
turbodreams954 is an unknown quantity at this point
I'll ask a dumb question, turbo is a T3 or T4 rear?
turbodreams954 is offline   Reply With Quote
Old 02-26-2008, 10:21 PM   #6
cutter
t3 rear. if the motor gets sold than the intake manifold will go. you will be the first one to know.
Old 02-26-2008, 10:30 PM   #7
turbodreams954
Price on turbo shipped to 33068
Old 02-27-2008, 03:38 PM   #8
cutter
$575 shipped to anywhere in the lower 48
Old 02-27-2008, 04:40 PM   #9
xsublimefrekx
xsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choices
dumb question but you wouldnt just part the head from the block would you?
xsublimefrekx is offline   Reply With Quote
Old 02-27-2008, 04:55 PM   #10
motoman6968
motoman6968's Avatar
motoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-known
ok bump! for a turbo that could eat a small child......
and some posi rep for probably mobb'n on the streets like no other...
... some icy white shoes and a tall t shirt i got the trunk on crack with neon lights in the back.......
motoman6968 is offline   Reply With Quote
Old 02-27-2008, 11:01 PM   #11
cutter
thanks, yes i have been wreckin shop since 83.
pm sent
Old 03-01-2008, 08:37 AM   #12
cutter
still up for grabs
Old 03-02-2008, 08:59 AM   #13
cutter
taking offers
