Old 02-26-2008, 11:01 AM   #1
Wes_s13
Wes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the roughWes_s13 is a jewel in the rough
Send a message via AIM to Wes_s13
Questions About Spec-V Brembo Calipers on S13!
I've tried searching everywhere for answers but found nothing. Was wondering if the sentra spec-v brembo calipers will bolt onto an s13 like the z32 calipers do. They look to be same as the z32 but im not sure. If they are direct bolt on, which rotors do i use? I heard you have to use maxima rotors but that seems awkward. If anyone can vouch for that, id appreciate it also. Would i also need to use a z32 mbc since these are 4 piston brakes? Also would the brembo lines fit onto s13? Thanks in advance guys..
Quick notes:
Sentra Spec-V brembo calipers direct bolt on onto 5 lug s13??
What rotors to use ?
Brembo brake lines fit onto s13? Or do i need new lines? If so, where do i find em?
THanks again
Smoke tires , Not drugs.
Wes_s13 is offline   Reply With Quote
