Old 02-26-2008, 05:15 PM   #1
180ways2slide
180ways2slide's Avatar
180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known
s13 quick help!!!
just hooked up my microtech ltx8 and now i need to know what is a good ignition switch. i got power and now when i turn the key power goes away i was told i did not have a good ign power where should i hook the ignition power up to for a good strong signal i assume i need a spot where when i turn the key the power doesnt drop. thanks guys
180ways2slide is offline   Reply With Quote
Old 02-26-2008, 08:08 PM   #2
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
all of the fuses inside of the car, on the driver's side is cut on by the ignition switch. just tap the wire into anything you want, i chose wiper blades because they are used the least daily.
louisdaboois is offline   Reply With Quote
