Old 03-05-2008, 05:23 PM   #1
S13Leprechaun
S13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant future
coilover noise, bad ball joint?
hey, well i had this problem in a prior, old thread before, but i THOT the problem was the wolt was broken off on one of the 2 bolts on the rear driverside coilover... so, now my question is, what else could the noise be? i replaced the bolt and its the same noise.... even if i push down right above the coilover i can hear it... and it rattles like crazy on tight turns cause of the diff... so its annoying me and i wanna fix it.... only thing i can think of is MAYBE bad ball joint!?!? but how do you check that/fix that? btw, they are kei office, if that helps... which means im fucked prolly.... and im not 100% sure its the coilover, just thats all that makes sense.... thanks for any help in advance!
-s13lep.
thurs. knights.
S13Leprechaun is offline   Reply With Quote
Old 03-05-2008, 05:29 PM   #2
SidewaysRPS13
SidewaysRPS13 is an unknown quantity at this point
look at your bushings also to see if there bad. To check the ball joints.just lift the car and see if the wheel moves left or right.
SidewaysRPS13 is offline   Reply With Quote
Old 03-05-2008, 05:34 PM   #3
S13Leprechaun
it will move left to right if the top ball joint is bad? that doesnt make sense. u sure?
thurs. knights.
Old 03-05-2008, 11:37 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
i had a similar problem as u i think.
i thought the coilover was loose, thus making clunking noises wen i go over bumps. i replaced the front lca cuz the balljoint was shot and now it disappeared.
i hope ur talking about the lca balljoints.....
lexus baby
5t341tH is offline   Reply With Quote
Old 03-06-2008, 03:17 AM   #5
S13Leprechaun
yeah i think soo.... ill do that... how mcuh did it cost to fix something like that? j/w. and what all did you have to get?
thurs. knights.
