Old 03-14-2008, 12:39 PM   #1
dragon_x330
dragon_x330's Avatar
dragon_x330 has a little shameless behavior in the past
Send a message via MSN to dragon_x330
KA KA-T 370cc/T25/N60 MAF Question
I'm going to be running that setup and was wondering if I would HAVE to put the MAF inbetween the intercooler and intake manifold(Blow-By), or could I just run it like normal and put it inbetween the turbo and air filter?
I was wondering because I'm not gonig to be running any A/F regulator/controller system yet, might be getting an Apexi AFC in the future.
Well I heard that this "ghetto" turbo system is pretty decent if you have a low budget and don't use any A/F management - as long as you gas up on 91 octane to prevent detonation.
Any inputs?
-OMGWTFBBQ
dragon_x330 is offline   Reply With Quote
Old 03-14-2008, 12:51 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
dude you could of just asked me. you'll will have to tune it. it runs decent with a tune but make sure you clamp the maf good enough when youre under a boost it will pop off. try not to crack the maf when clamping it too.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-14-2008, 12:53 PM   #3
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
At the VERY least, I'd run AFC & tune it with a wideband.
In the best case w/o tuning, you'll run pig rich -> wasting tons of money on gas.
In the worse case w/o tuning, you'll blow something up -> will cost you A LOT more than investing in at least some sort of fuel management & tuning.
You technically could put it either place (given you tune for it). And since you are not running any management whatsoever, I would say you car will most likely run very shitty.
If you search, you should get your answers... there are pros & cons running either setup.
I'll give you one pro of each, you can search the rest:
- one reason people run between intake manifold & intercooler is to help w/ issues w/ open atmosphere bov's.
- one reason people run on the filter/pre-turbo side is because it's easier.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 03-14-2008, 01:01 PM   #4
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
I recommend waiting the extra amount of time it takes you to get the money for a goof fuel management so than you dont have to worry about running rich or blowing anything up...whats a few weeks to wait for everything to be done right...? Just my 2 cents
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 03-14-2008, 01:15 PM   #5
dragon_x330
Alright, thanks for the input, guys.
-OMGWTFBBQ
