Center bearing support bolt problem
Pulling the driveshaft for a 5 speed swap. One bolt on the bearing support bracket came out fine. The other loosened a few threads and now will spin forever. Looks like there are threaded inserts in the chassis. I'm thinking one of the inserts has broken free, but I can't see up there to see if it's turning. Sooo, bolt won't loosen and bracket won't fall free.
Anybody have this problem or have any ideas ?? Thanks |
If I can get the bolt/threaded insert to come out I would weld the threaded part back in. I'm just guessing that the insert broke free. I can't see up there to be sure. Pulled the seat out and cut the carpet to see if I could get to it from inside but no luck
Thanks, any other ideas? Have been thinking a can of gas and a match, but I know as soon as I throw the match, the bearing bracket will fall free on it's own. |
![]() Join Date: Sep 2006
if you can, wedge something between the body of the car, and the bolt head. then, as you turn, pry them apart. That may put enough pressure on the bolt to help find the threads again, or hold the insert still so the bolt can unscrew.
or get a one piece shaft for a few hundred ![]() |
#5 |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
Easy fix, get a one piece driveshaft made and never look back. Its lighter and you do not lose as much torque transfer or hp, due to how sloppy center support bushings are in the first place.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html Last edited by drift freaq; 03-15-2008 at 08:09 PM.. |
