Redtop SR Wiring Mess HELP!!!
Ok so i was blessed with the task of doing the wiring harness for a friend of mine's SR swap. The only problem is he ordered the motor and harness from a company in canada and instead of disconnecting connectors they just cut wires leaving me a cluster F#@k of wires. i got just about all the wires sorted out and cleaned up but i just have a few wires left that i am not sure of and are hoping u guys could help me out. here it goes:
(are these wires needed???) *Blue/White wire Intake air temp sensor Pin #45 in ECU connector *Blue/Yellow wire Exhaust gas sensor Pin #26 in ECU connector *Purple/White wire Power steering oil pressure switch Pin #43 in ECU connector i also have 2 wires that come from the coil pack connector down the harness and are cut on the other end one is a thick Blue/Red wire the other is a Red/Blue wire. (do these go to another connector? if so where?) THANKS FOR ANY HELP!!!! |
