Old 03-19-2008, 09:41 AM   #1
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
S13 Troubles starting
Hey, I have a 1992 240sx, it's having troubles starting. When it refuses to start, all I hear is a click when I turn the key. Sometimes after a few tries it'll just start. Dying battery? Dying starter? Dying.... something else? haha
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 03-19-2008, 10:09 AM   #2
Onitsukagirl
Onitsukagirl's Avatar
Onitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really niceOnitsukagirl is just really nice
hey, i think it's your battery. It doesn't have enough juice to start so it's just clicking. Next time you have an issue, try troubleshooting it yourself. Like this.... go to auto zone with your battery and have them test it, if it's bad, which most likely it will be, buy a new one, re-install and wallah.. If that does not work then you may have a stuck starter.. just search because some people will flame you for asking something that has already been covered too many times.
Onitsukagirl is offline   Reply With Quote
Old 03-19-2008, 12:14 PM   #3
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
If your battery & starter are good, then check your clutch relay & your ignition switch. The contacts inside your ignition switch module go bad after a while. You'll need a voltmeter / continuity tester to check it.
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 03-19-2008, 09:35 PM   #4
i8yourfwd
i8yourfwd's Avatar
Thanks for the replies.
How do check the ignition switch module?
Yeah, I tried searching, and it turned up a million threads I didn't need heh. I've been here long enough to know to use the search at least ;P
Old 03-19-2008, 09:59 PM   #5
Jadeskyline
Jadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choicesJadeskyline has made poor choices
Send a message via AIM to Jadeskyline
its in your steering column take off plastic trim and you sould see your ignition wiring right there...positive and neg hook up your voltmeter put key to on position and you should get a read if not thats ur problem...i might have missed something its been awhile since i did it so 4give me if i omitted something
Jadeskyline is offline   Reply With Quote
Old 03-20-2008, 03:59 AM   #6
IRN
IRN's Avatar
IRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really nice
could be as simple as corrosion on your battery terminals. dont know about auto zone but kragen tests your battery, alternator, and starter for free. grab a volt meter and see if your battery has enough juice at a stand still.
IRN is offline   Reply With Quote
Old 03-20-2008, 04:08 AM   #7
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
those are the usual signs of failing starter
markyboi is offline   Reply With Quote
Old 03-20-2008, 07:44 PM   #8
i8yourfwd
i8yourfwd's Avatar
I tried jump starting it this morning, all I got was a click from under the hood. Looks like it's the starter :|
Old 03-20-2008, 07:52 PM   #9
muddafakka
muddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfection
Yeah I had that clicking issue a while back...it's a nuisance. The battery was fine when I tested it. I replaced the old starter with one by Duralast. It's been working great ever since.
muddafakka is offline   Reply With Quote
