![]() Join Date: Mar 2007
![]() ![]() ![]() Feedback Score: 9 reviews
bogging issue
Well the other day i put on a intake on my car.After i installed it and drove it it would bog whenever i floored it.I checked all the hoses and made sure everything was on correctly.I put my stock intake back on and everything ran fine.So i thought i could just run the cone filter at the end of the maf.I tried that and it would bog again when i floored it.Put the stock air box back in and it ran fine
driftfaction.com @driftfaction |
is a ka24de.and yes i do have a dry flow filter.I also took a filter off my friends car and it did the same thing
![]() Join Date: Jan 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Sounds like a vacuum leak after the MAF. Are you sure there are no leaks or unplugged fittings on the new intake?
"Genius may have its limitations, but stupidity is not similarly handicapped." |
#5 |
all the fitting are good.when i take the cone filter out and put the stock airbox back in everything runs fine
#6 |
figured it out.for some reason it was the fuel pump.My car is way faster now to.when i took the old pump out the filter was black.
#9 |
so u replaced the fuel pump or u just replaced the filter? i never took a fuel pump out so im just curious if its the same problem for me. thanks
#10 |
i replaced the fuel pump.I did the filter to awhile ago with a z32 one but the pump was the actual problem.It took about 15 minutes to replace.
