Old 04-05-2008, 09:03 AM   #1
bonomo
bonomo can only hope to improve
ka24de Cam degreeing
this is what i got when i degreed them where they sit stock BC 264 264 correctme if i did it wrong cause im new to timing cams but if im looking at it right there wayyyy off
intk open @.050 =20 deg
intk closed @.050 =49 deg
exh open @.050 =43 deg
exh closed @.050 =14deg
claculate i get
Your cam has an Overlap of 34.00 degrees and has in Intake Duration of 249.00 degrees.
The Exhaust Duration is 235.00 degrees.
The Inlet Cam has an Installed Centerline of 104.50 degrees ATDC.
The exhaust cam has an Installed Centerline of 104.50 degrees BTDC.
bonomo is offline   Reply With Quote
Old 04-06-2008, 04:57 PM   #2
bonomo
come on some one knows somthign about this!
Old 04-06-2008, 05:00 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Can you degree cams without adjustable cam gears? I don't think you can, and I haven't seen anyone selling adjustable gears for KADE's.
Old 04-06-2008, 07:08 PM   #4
bonomo
lol yes i do and im seeing if my settings were right or if im doing it right
Old 04-06-2008, 07:18 PM   #5
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
I have no clue what you're saying..
but on the same thing (ka24de, bc264) i have a spec sheet saying:
Intake:
advertised duration - 264*
duration @ .050" - 218*
valve lift (inches) - .375"
Valve lift (mm) - 9.52
Valve lash (inches) - .008"
Exhaust:
Valve lash (inches) - .010"
My iTrader rating!
babowc is offline   Reply With Quote
