Old 04-05-2008, 10:23 PM   #1
Trig3r
Trig3r is making a name for him/her selfTrig3r is making a name for him/her self
KA z32MAf? and ka24de
How hard is it to wire in a z32 Maf to a 95 Kade24 setup, and whats the gain.? any links and input would be helpful... tryin figuring this one out my self but it isnt workin out.thnx
Trig3r is offline   Reply With Quote
Old 04-05-2008, 10:31 PM   #2
adictd2b00st
adictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to behold
Send a message via AIM to adictd2b00st
correct me if i'm wrong, but if this is an NA ka i don't know what "gains" your really expecting to see?
adictd2b00st is offline   Reply With Quote
Old 04-05-2008, 11:00 PM   #3
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
why do you want a z32 maf if you dont even know the "gain"?
aNskY is offline   Reply With Quote
Old 04-05-2008, 11:37 PM   #4
Trig3r
Thnx for the info.... i was just wonderin didnt realize that the MAF swap where on sr20s........ just made an azs of myself... all in good nature tho.
Old 04-05-2008, 11:47 PM   #5
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
adding a maf will not add power to your setup. People switch to Z32 mafs when the stock maf reached its limit. Unless your ka-t or SR dont even worry about getting a Z32 maf.
norcal_black240 is offline   Reply With Quote
Old 04-06-2008, 12:06 AM   #6
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
you can't even put it on there unless you have an safc2 or other tunable device (ie stand alone, megasquirt, get your ecu tuned for the maf).....its values for measuring the airs are different and your car will run like shit.
doing the maf alone will gain u nothing. doing the maf with a turbo, bigger injectors, and something to tune with will gain u more power.
z32 mafs have a bigger bore, they can measure more air than a stock ka maf, that is their benefit. they are not a power adder.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 07-24-2008, 01:48 PM   #7
turbo98
turbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of lightturbo98 is a glorious beacon of light
I know this thread is old, but what are the limits power wise of the stock ka maf?
turbo98 is offline   Reply With Quote
Old 07-24-2008, 01:55 PM   #8
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
its about 300hp for the KA maf and the z32 is about 550hp. Keep in mind that that is a measured amount of airflow.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-14-2009, 12:51 PM   #9
91tofordee
91tofordee is an unknown quantity at this point
i believe megasquirt doesn't use a maf....just saying.
91tofordee is offline   Reply With Quote
Old 05-14-2009, 02:31 PM   #10
projectRDM
projectRDM's Avatar
KA MAF reaches it's limit at more like 250-260hp.
FORMERLY R240NA
