Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 04-07-2008, 03:40 PM   #1
[email protected]
kuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond repute
Introducing SPL PRO aluminum differential bushings for S13
By popular demand, we are releasing a new aluminum bushing kit to mount the J30 or 300ZX differential to the S13 rear subframe.
Our CNC machined T6061 aluminum differential mounting bushings will hold the differential solidly to the subframe, reducing wheel hop and improving power transfer to the ground. In addition, reduced movement of the differential during hard launches can also help prevent damage the drive shaft and half shafts.
This kit includes all bushings to press onto the differential pumpkin, and new Nissan mounting bolts.
Pricing for the S13 diff bushing kit is $89.
http://www.splparts.com
kuah@splparts.com is offline   Reply With Quote
Old 04-07-2008, 04:10 PM   #2
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
what about for s14?
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 04-07-2008, 04:12 PM   #3
[email protected]
Originally Posted by devonkyle77 View Post
what about for s14?
S14 solid aluminum differential bushings are $139:
Old 04-07-2008, 06:15 PM   #4
a_ahmed
a_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfection
but doesn't the s13 subframe not have any bushings for a differential and its direct and that instead the s14/s15 are the ones with bushings... just curious... or does this mean to actually fit an r230 (300zx) differential into the s13 subframe or something?
Also I am waiting for you new RUCA release heh... any more info?
a_ahmed is offline   Reply With Quote
Old 04-07-2008, 06:22 PM   #5
LongGrain
LongGrain's Avatar
yes, its for putting a j30/300zx diff in an S13 subframe.
LongGrain is offline   Reply With Quote
Old 04-07-2008, 06:29 PM   #6
[email protected]
The S13 diff pumpkin has no bushings, but the J30, 300ZX, or S14 diffs (all R200) have bushings on the pumpkin. This kit makes it convenient to install a J30, 300ZX or S14 diff on a S13 subframe...
The v2 RUCAs should be ready in about 2 weeks...
Old 04-08-2008, 12:11 AM   #7
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
would you happen to also have polyurethane bushings?
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
Old 04-08-2008, 08:05 AM   #8
[email protected]
Sorry we do not offer polyurethane bushings for subframe/diff mounting. We do not recommend polyurethane in those applications since they experience a static load, the polyurethane will creep (cold flow) over time changing the diff mounting angle.
Old 04-08-2008, 10:48 AM   #9
a_ahmed
What about s15 dif .. cause i want to go HLSD :P
Cant wait to get the rucas Hopefully ull have promo :P
Old 04-08-2008, 11:33 AM   #10
naed240sx
naed240sx's Avatar
naed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the rough
Just swap the helical differential into your s13 or s14 pumpkin. No need for special mounts
naed240sx is offline   Reply With Quote
Old 04-08-2008, 12:13 PM   #11
[email protected]
You can use this S13 kit to mount a S15 diff pumpkin to a S13 subframe. Or use the S14 kit to replace the diff bushings for a S15 diff pumpkin on S14/S15 subframe...
Old 04-08-2008, 12:57 PM   #12
GSXRJJordan
GSXRJJordan's Avatar
Cool!! Thanks for bringin the heat, Kuah!
Old 04-08-2008, 01:09 PM   #13
Dousan_PG
Dousan_PG's Avatar
im looking forward to seeing the new RUCAs!!!
Aaron
Pink GodziRa
Old 04-08-2008, 01:14 PM   #14
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
awesome stuff
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-08-2008, 01:16 PM   #15
LongGrain
LongGrain's Avatar
werd.
msglngth
Old 04-08-2008, 03:05 PM   #16
a_ahmed
very sexy thanks for the info
Old 04-08-2008, 05:04 PM   #17
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
I have a J30 LSD in my S13 without any bushings, just straight bolted it up where the old one was. So I guess thats bad then huh? How bad is it? Ruins my differential bad? Might move around on shifts and throttle engagement bad? How much should I get bushings. I have had it in since the beginning of winter. If you think its already ruined then hell with buying the bushings.
In the market for a Clean Coupe
ripnbst is offline   Reply With Quote
Old 04-08-2008, 07:50 PM   #18
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i think you will just rip your driveshaft apart....with that torque and vibration. it will surely kill your diff too
Old 04-08-2008, 07:54 PM   #19
[email protected]
You can bolt it up with the stock rubber bushings on the pumpkin. It will move around a little more than is ideal for performance, but probably won't kill the diff assuming the existing rubber bushings are still in good condition.
Old 04-10-2008, 09:20 PM   #20
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
These can also work on s13 right? (installed upside down?)
reccakun08 is offline   Reply With Quote
Old 04-10-2008, 11:44 PM   #21
GSXRJJordan
If you had a S14 or similar LSD, then yes. If you have an S13 LSD, then no.
Old 04-14-2008, 09:12 PM   #22
pete240
pete240 is making a name for him/her selfpete240 is making a name for him/her self
+1 I too am looking forward to seeing these new rucas....
pete240 is offline   Reply With Quote
Old 04-15-2008, 07:48 AM   #23
water
water has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud of
^Me too since I'm waiting on the set!!!
water is offline   Reply With Quote
Old 04-15-2008, 02:31 PM   #24
gottdeskrieges
gottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enough
Send a message via AIM to gottdeskrieges
Im using a q45 rearend which would I use, apologize for the noob question.. thanks
gottdeskrieges is offline   Reply With Quote
Old 04-15-2008, 07:04 PM   #25
[email protected]
Q45 diff on a S13 subframe should also use this S13 solid diff bushing set...
