Old 04-10-2008, 01:21 PM   #1
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
SR injector not firing, getting +12v and shows continuity to ECU? WTF
Alright, I'm helping a friend out with his SR wiring and there's an odd problem we're having.
Motor is a s14 Zenki SR with a Nissan remanufactured ECU.
Injector #1 isn't firing. There's +12v going in and there's continuity between the ECU and the injector, so I know there's a power and ground.
We pulled the injector clip out while the engine was running and NOTHING.
-The injector is good. We originally thought it was the culprit and replaced it with one from a low mileage, working SR motor. Tested within FSM spec, 10.2 ohms resistance. We attached to a 9v battery while it was on the car, and it started to bog & smoke started pouring out, so I know the injector isn't seized.
-There's spark, I tested the coilpack and I can see the huge spark grounding out to the motor. I replaced it with a working one just in case.
-I removed the coilpack and cranked the motor, and looked inside the cylinder. No fuel on the cylinder or on the plug.
-Injector plug & harness look fine. No bent prongs, recessed terminals, nothing. I tried wiggling it while it was running and still got nothing.
- I ghetto rigged some wires directly from the plug to the injector, but it still wasn't firing. I don't know if it made a connection, but i'm going to try that again later.
WTF is the problem? It seems like it would be in the plug but I'm getting nothing.
Anto is offline   Reply With Quote
