PWR vs. Cosworth head gaskets
hey guys i am looking into getting a mls head gasket for my sr20det rebuild. pwr gasket is $220 and cosworth is $125. Both seem to be reputable. I am willing to spend the extra $95 if its worth it. Anyone with experience with either or both?
#2 | |
Cosworth but then again, Cometic makes head gaskets for Cosworth. |
hmm, might as well go with cometic then if i am going to go with cosworth... PWR is supposedly like the Apexi and Greddy head gaskets, and i only hear good things about that design.
#5 |
![]() Join Date: Dec 2006
+1 Power Enterprise
Im using one. Its Worth it ^_^b
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#8 |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
Let me get this straight. The COSWORTH gasket is cheaper than the PWR one, significantly cheaper, and you are still considering the PWR gasket? SERIOUSLY? COSWORTH, that company with like 50+ years of racing heritage including DOMINATING F1 for years! I really don't think this is even a question. What could possibly be any better about the PWR gasket?
#9 |
Where did you hear that. Eric Hsu even showed testing between Cometic and Cosworth and you can see a clear sealing difference between the two, if they were the same the results would be the same.
#10 |
Seriously, get a Cometic straight from cometic. Unless one of those companies offers a rolled edge that wraps over the layers other than that then the extra money it is definitely not worth it.
Just remember with mls you need to get your block and head prepped and you should be using ARP studs. If you do this you should easily be safe to 700+hp. The thing people tend to forget about mls gaskets and why some people think cometic makes crap is because the only thing that can go wrong with these is a user error( not prepping to correct roughness specs on the block and head) Prep it and you will be more than happy. The Power MLS Full Grommet looks like it has the rolled edge, really it is way over kill for you, you will never notice it with a 300hp goal, and really if you are gonna shoot for higher goals where you are thinking about getting a rolled edge gasket you should just o-ring your engine as it is the proper way to do it. By the way cometic always has great customer service and response at least for me. here is their number 800-752-9850. Good Luck |
#14 |
ak slick: i have heard lots of negative feedback on the cometic, but i have also heard positive feedback. its seems that most people that havent even used it trash talk it because of some horror stories they have heard. I am thinking as long as everything is properly done it should work just as good as any other head gasket.
Oh and why use ARP studs when oem ones can hold more than enough power for me? |
#15 |
The ARP studs are just better insurance and they do help even at your power levels. I've use Cometic in nearly every performance engine I've built from Honda's to Nissan's and never had any problems. I was going to use the Cosworth in my SR motor I'm building now just to see how I like their new stuff. For the power you're talking about the stock will work and all the others are just better insurance but as several people have said, the prep on the block and head are more important than with the stocker.
#17 |
i dont feel comfortable getting apr studs since i have heard there has been issues with them stripping out the block because they dont have the correct thread depth. R.S. Enthalpy has made not of this and only builds SR's with OEM head bolts. just doesnt seem neccisary especially since i hear they arent neccisary till you go over 400hp, same as connecting rods.
#19 |
![]() Join Date: Jun 2004
Edit: (In this post what you refer to as the "rolled edge", I am calling the fire ring)
From my understanding the Cosworth does not have a fire ring on it. I only like head gaskets with fire rings. I use OEM headgaskets over metal headgaskets all the time(because they have a fire ring), with NO PROBLEMS. Other wise it is apexi, or Power Enterprises. So, I am going to say Power Enterprises. Prove me wrong. Tim: Just use stock.
[email protected] Last edited by johngriff; 04-14-2008 at 04:10 PM.. |
#24 | |
![]() Join Date: Aug 2005
Eye on the Prize |
#25 | |
barf Apexi (integrated Fire ring design) (Trust me I'm not a huge fan of Apexi, but the Headgasket is one thing they just nailed) or call Mazworx they have custom designed one they worked with Power Enterprises design available for various larger bore sizes up to 90mm now.
Like Me on FaceBook ![]() |
#27 |
![]() Join Date: Aug 2006
![]() ![]() ![]() Feedback Score: 1 reviews
Apex-i, enough said! Daily drive my ~320whp without worrying about blowing a head gasket. I also love the little fancy Apex-i Tab infront of the engine
![]() Steve. |
