Old 12-25-2001, 09:31 PM   #1
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
My idling has recently started doing some funny things.. with or without the AC on.. it is weird, when at a light.. it will go up to 1000 rpms,, then drop fast to 500,, then slowly go back up... then drop back down to the line... etc... i don't have any engine mods at the moment.. any ideas?
AJ is offline   Reply With Quote
Old 12-25-2001, 09:41 PM   #2
Guest
Posts: n/a
well there are lotsa things that it can be i work at nissan and i have the same thing it went away a lil after i did a mjor tune up (fuel filter injection cleaning oil plugs wires timing setting idle) there is a tsb out for that i have it printed out from work i will try and scan it and post it up here tomorrow. also try regrounding your maf. and checking the voltage on your tps it should be no more or less thanhalf a volt from what i remember
Old 12-25-2001, 09:50 PM   #3
AJ
tps?!.. ehh...  what is that?
also, how much does a major tuneup cost? usually, from a dealer?.. i might want to do that oncei have intake and exhaust.. etc... what do you think?.. should i wait to solve the problem then if it isn't the MAF or the tps?
Old 12-25-2001, 09:59 PM   #4
Guest
Posts: n/a
sorry bout the acronyms tps is throttle position sensor its by your throttle body there are 2 screws on the top and bottom lossen those and you can move it like the distributer. you would need a multimeter set on volts of course.
maf ios mass air flow sensor thats by your air box usually with most nissans they need to be regrounded
a major tune? hmm i think its 199 at my job but whjy go that way all it is are the following whihc can be done by anyone not mechanically inclined.
sparkplugs airfilter new plug wires, fuel filter,oil change trnas fluid change i belive.
what kinda car do you have a s13 correct? if yoiu need tips or help i can try and take some pics of how to do most of the stuff.
the tsb (technical service bulliten) whihc i havent done the whole thing except check the ecu code got me a lil stumped thats probably the hardest part.
but if needed like i said i dont minnd helping you and saving lotsa money after all that can go towards your muffler and cai
Old 12-25-2001, 10:57 PM   #5
AJ
thanks man! thats awefully nice of u!.. i'll check to make sure the MAF is grounded, and if that doesn't work. i'll attempt the Tps thing,, i might need some more coaching on that, but i can prob figure it out, i have an s14, but i'm sure the engine bays don't differ that much, i'll email ya if i get myself into trouble, thanks again man.
Old 12-26-2001, 12:50 AM   #6
Guest
Posts: n/a
Throttle Position Sensor...my prob was linked to TPS...got the part for 50 bucks and putted it in..my car now has a very good idle at 500 and it stays there...
Old 12-26-2001, 12:37 PM   #7
AJ
awesome, u guys are the shit.. if i get time today, i'm going after the MAF and TPS,,, if screwing with them doesn't work, i'll order that part.. thanks again!..
