Old 04-16-2008, 03:38 PM   #1
Driftapparel.com
Driftapparel.com's Avatar
Driftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura aboutDriftapparel.com has a spectacular aura about
cylinder 3 spark!?
Wow this is crazy! Anyone know what it could be?
So when I am drifting or just spinning messing around if I boost too much (it seems) my cylinder 3 spark plug gets smashed and I loose the cylinder until I pull it out and re-gap it. It's all pitted too as if something is hitting it. The wierd thing is that it is only the 3rd spark plug back!
Any input would be greatly appreciated
Thanks
-Brett
Driftapparel.com is offline   Reply With Quote
Old 04-16-2008, 05:14 PM   #2
AllMotorS13
AllMotorS13's Avatar
AllMotorS13 will become famous soon enoughAllMotorS13 will become famous soon enoughAllMotorS13 will become famous soon enoughAllMotorS13 will become famous soon enough
well...something's probably hitting it, haha. what type of plug are you using? anything under a free rev, or is it just under a load? how much boost?
89' Two Tone - All Original
AllMotorS13 is offline   Reply With Quote
Old 04-16-2008, 05:48 PM   #3
Driftapparel.com
I am using the stock NGK spark plugs ill post the code tonight after I get home. I was using wrong spark plugs before and it was doing it all over the rpm range now that I have the right ones in its only under boost. Stock S13 redtop SR20 boost.
Thanks alot
Old 04-16-2008, 05:53 PM   #4
AllMotorS13
i believe they should be bkr6e for a relatively stock SR. not sure why it would only mess up #3. have you tried actually looking through the spark plug hole into the cylinder?
Old 04-16-2008, 10:50 PM   #5
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Check the top of the piston for any marks that would indicate the piston hitting the spark plug. Also check the threads for the spark plug hole for any damage.
Perhaps the piston rod isn't seated correctly on the crankshaft? Bad bearing? Loose con rod bolt?
HalveBlue is offline   Reply With Quote
