Old 12-22-2001, 11:53 PM   #1
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
Hey, I am gonna change all my fluids soon. What do you recommend for tranny fluid, as well as differential fluid?
BadMoJo is offline   Reply With Quote
Old 12-23-2001, 04:30 AM   #2
tristarx
tristarx is an unknown quantity at this point
If you car is a daily driver that sees the track very rare, then just get the regular Valvoline or name branded 70w90 or 75w90, etc. diff fluid for your tranny and diff.
If you attend the track alot per year, then we recommend using the good stuff which cost alittle more such as Redline oils.
Tx.
tristarx is offline   Reply With Quote
Old 12-23-2001, 08:44 AM   #3
tnord
tnord's Avatar
tnord is an unknown quantity at this point
i personally use Mobil-1, can't remember the weight, Mobil-1 engine oil is excellent, so i trust them with the diff and transmission as well, it's $8 a quart, like tristarx said though, redline has quite an extensive product line and is very reputable, they are sure to have something to fit your needs, if i wasn't using Mobil-1, i'd use redline
tnord is offline   Reply With Quote
Old 12-23-2001, 01:03 PM   #4
BadMoJo
BadMoJo's Avatar
so, 70w90 or 75w90 for both?
Old 12-23-2001, 02:04 PM   #5
tnord
tnord's Avatar
i'm not sure what the weight is, it doesn't say on the bottle, but if you're getting Mobil-1, there's only 1 weight available to my knowledge, if you really want to know what weight is appropriate, call up redline, i'm sure they'd be happy to help, i'm sorry i don't know more
Old 12-24-2001, 02:11 AM   #6
tristarx
70w90, or 75w90 is fine.  Those are the most common ones, so anywhere in the range of "70"s w "90"s.
If you decide to use Redline, just grab the "MTL" for the tranny and 75w90 for the rear diff.
Some people like to mix and match adding 1/2 quart of MTL and 2 quart of 75w90 Redline in their tranny, just a matter of personal preference and what works for your tranny.
Tx.
Wayne
http://www.phase2motortrend.com
Wayne[br]http://www.phase2motortrend.com
