Old 04-21-2008, 05:59 PM   #1
Vinny
Vinny's Avatar
Vinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the roughVinny is a jewel in the rough
torque damper
So I have a 1995 240sx with a ka24de and I just got my torque dampener from genki tuning but it didn't come with instructions. I called the company and asked if they had any or were able to get a copy of any instructions on how to install it and they still had nothing.
Checked around the net, but closes thing I could find is a video of before/after youtube clips of a torque damper effects.
Does anyone know how to install one? I've been trying all different possible ways, but the bracket they sent with it makes no sense in how to position it to fit on properly.
Any help would be greatful. Thanks!
Kolab Agency | Limitless Society
Vinny is offline   Reply With Quote
Old 04-21-2008, 06:05 PM   #2
agustin lopez
agustin lopez's Avatar
agustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud ofagustin lopez has much to be proud of
you need to modify it. possibly a new bracket. ive never found a torque dampener for the ka, then again i could be totaly wrong. good luck!
agustin lopez is offline   Reply With Quote
Old 04-21-2008, 06:07 PM   #3
Vinny
Vinny's Avatar
The thing is though, I emailed the company before I purchased it and the guy said it was for the us-version 240sx and doesn't work with "swap engines" So that kind of throws me off.
If I have to modifiy it, how so?
Old 04-21-2008, 06:13 PM   #4
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
well.. i know for the sr, theres open threaded holes above the ex. mani that you screw them into... I guess just look for something that you can thread the screws in. hell, ghetto fab it to a valve cover screw if you need to, i guess?
@adrianfromthecastle
Old 04-21-2008, 06:18 PM   #5
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
you have to cut the mounting bracket to the block to make it fit the ka
markyboi is offline   Reply With Quote
Old 04-21-2008, 08:52 PM   #6
Vinny
Vinny's Avatar
Any other options guys? I just tried again with a friend. We tried heating the bracket and bending it, but genki tuning makes some quality welds, lol
I'm considering just going to a metal shop and have someone make a custom bracket for me. I can't believe it's just a bracket preventing me from putting it on.
Old 04-21-2008, 09:01 PM   #7
S14DB
AFC #1
S14DB's Avatar
The circle bracket goes on the shock tower and the little one on the head.
Old 04-21-2008, 09:03 PM   #8
Vinny
Vinny's Avatar
thank you mister obvious.
Old 04-21-2008, 09:21 PM   #9
S14DB
AFC #1
S14DB's Avatar
pictures would help...
Old 04-21-2008, 09:24 PM   #10
!Zar!
!Zar!'s Avatar
You should just sell it and buy new motor mounts.
Old 04-21-2008, 09:33 PM   #11
Vinny
Vinny's Avatar
I'll try to get pictures tomorrow guys.
As for motor mounts, I wanted to get the torque damper in order to save the motor mounts. If it didn't, new motor mounts were my second option, but while I have this TD, I figured, why not try and figure out a way to install it and help out the community in how to modify or adjust?
Old 04-21-2008, 10:47 PM   #12
projectRDM
projectRDM's Avatar
If you mount it on the passenger side there's two places it lines up the KA intake manifold. One is on top, one behind. Both will require you to drill/tap, but they work without a bracket at all.
No, I don't have pics. Mount it and set it across the manifold, if you don't see where it lines up you're blind.
FORMERLY R240NA
Old 04-22-2008, 07:30 AM   #13
Vinny
Vinny's Avatar
I actually tried that last night too. I saw the 2 spots.
Would it be as efficient though compared to original spot is my question. I'll also have to have someone drill/tap it for me if I go that route.
Thanks!
Old 04-22-2008, 07:55 AM   #14
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
it would be more efficient to get new motor mounts
bigOdom1 is offline   Reply With Quote
Old 04-22-2008, 08:36 AM   #15
projectRDM
projectRDM's Avatar
Thanks!
The damper is nothing more than a rod. Mounted on either side it does the exact same thing.
FORMERLY R240NA
Old 04-22-2008, 01:37 PM   #16
neukin
neukin's Avatar
neukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really nice
Send a message via AIM to neukin
how long is that shock? measure the center of one bolt hole to the other. if you want it just alittle compressed between the brackets give me that measurement. Ill make a bracket for ya just lmk where you kinda want it mounted or what points you want to use otherwise ill make my best judgment.
btw how much was your kit?
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803
-->Neukin Store<-- -->DRIFT Clutch Store<--
neukin is offline   Reply With Quote
Old 04-22-2008, 01:51 PM   #17
Vinny
Vinny's Avatar
awesome, when I got home from work I'll try to get some measurements and pictures done.
I got the kit on ebay from genki tuning.
All together with shipping it turned to about $50.
There's no complaints in quality or pieces broken, it's just not a bracket for the ka motor, lol
Old 04-22-2008, 04:12 PM   #18
steve shadows
steve shadows's Avatar
Honestly comparing a couple cars we have installed them on and tracked. they do very little to improve anything compared to installing the appropriate stiffness or new racing motor mount.
I reccomend Nismo (for a car that will street use at all)
I reccomend Peak (for race car only)
cheers
Like Me on FaceBook !
Old 04-22-2008, 04:27 PM   #19
johngriff
johngriff's Avatar
I'd rather use a turnbuckle with rubber bushings on the ends than a shock absorber. Its going to die, don't worry.
[email protected]
Old 04-22-2008, 05:34 PM   #20
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
some ghetto guys around here, well not really ghetto but took this idea from japan, he just put an exhaust hanger and ziptied it to his strut tower bar in between the motor. or just get a bar and weld it to your strut tower bar bracket and make a bracket for it to bolt to the motor with
Slip Gypsies Blog
not sure if you realize this
Old 04-22-2008, 08:44 PM   #21
Vinny
Vinny's Avatar
Alright, got some pics guys.
Bracket is burnt and shit cuz a friend and I were trying to heat and bend it ourselves. It was working, but it was just ALOT of effort.
You can see in the last pic, that they welded a small bracket on there to reinforce it.
I'll try to get pictures of it displayed on the car tomorrow, but atleast now you know what the bracket looks like.
Old 04-22-2008, 08:44 PM   #22
S14DB
AFC #1
S14DB's Avatar
If you cut most of them open they are rubber bushing not a gas/oil.
That's an SR bracket they gave you.
Old 04-23-2008, 10:56 AM   #23
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
valve cover bolt would be retarded. You'd be leaking at that spot in a day.
AFAIK the only torque dampers I have ever seen offered for the KA were just SR ones sold with 'modifications may be needed'.
What's the link to the product?
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 04-23-2008, 10:59 AM   #24
Vinny
Vinny's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEAFB:IT
funny thing is, on their picture they don't show the welded piece on the bracket there, but on the part they delivered there is. Kinda makes me mad.
Old 04-23-2008, 11:31 AM   #25
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
its ebay crap
just get new motor mounts and it'll be better. torquew dampeners are just temperary solutions.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-23-2008, 11:35 AM   #26
Vinny
Vinny's Avatar
...actually, it's pretty good quality. The welds are pretty damn good too.
You people are giving me no help in telling me to get motor mounts when I already bought the damn torque damper.
Old 04-23-2008, 11:40 AM   #27
alkemyst
alkemyst's Avatar
Originally Posted by s13silvia123 View Post
its ebay crap
Torque Dampeners have a different purpose than what mounts do.
They are the modern version of bolting a piece of chain to the body from the head.
There is not much to them though. You just need a solid engine mount and solid body mount. The shock is to make it not so harsh as well as not so 'breaking'.
Some high powered monsters in the day would rip the chain out of the body mount...along with the mount itself.
Old 04-23-2008, 11:44 AM   #28
ill_concepts
ill_concepts's Avatar
ill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfection
Send a message via AIM to ill_concepts
this is why you dont buy off ebay.. make your own bracket that looks like ur only option, good luck
ill_concepts is offline   Reply With Quote
Old 04-23-2008, 11:46 AM   #29
projectRDM
projectRDM's Avatar
Had you read the ad though you'd see where it says 'Silvia S14'. Although a lot of shit nowadays is written to confuse, denoting Silvia would more than likely mean it's designed to fit an SR. There's also no mention anywhere of a KA, hence it being 'wrong' in your eyes, but you actually just bought the wrong piece. Either way you can bolt it to the intake just like I said and throw the bracket in the scrap pile.
FORMERLY R240NA
Old 04-23-2008, 11:46 AM   #30
projectRDM
projectRDM's Avatar
Ebay or not, no one makes a KA damper. He could have paid twice the money for a name brand piece and got the exact same thing.
FORMERLY R240NA
