Old 04-21-2008, 09:53 PM   #1
Tearlessj
Tearlessj's Avatar
$5 for anyone can solve my KA problems!!!
Ok heres the deal. My car runs extremely rich, I average about 12-14 mpg. Also my car can NOT hold idle when I am off the gas. I have to heel toe at every stop light to keep the car running. The car backfires sometimes and rough idle at startup. Sounds like my car has some huge cams.
I ran the codes and got:
34 - Knock sensor
45 - Leaky Injector
92 DOHC
The only mod is an exhaust.
The person who suggest the correct fix will get $5!
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 04-21-2008, 09:55 PM   #2
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
does it sounds like a subie? if so it might be a bad injector.
180sx_Drifter is offline   Reply With Quote
Old 04-21-2008, 09:56 PM   #3
!Zar!
!Zar!'s Avatar
You need a one or more new injector o-rings. They tend to go out fairly often on KA's.
Best way to check it to unplug each injector while your car is running and take note if any don't make a change when you pull one.
Also do the same to your spark plugs. by pulling one by one and listen for a prominent clicking.
Old 04-21-2008, 09:56 PM   #4
eclipse_dsm
eclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond repute
Fuel injector O-rings. Try that. GL!
eclipse_dsm is offline   Reply With Quote
Old 04-21-2008, 09:58 PM   #5
Phlip
Yes, I look like that
Phlip's Avatar
Everything they said and IACV.
I'm not even after the trap, just trying to help
Weirdo
And I write too!
Old 04-21-2008, 10:00 PM   #6
eastcoastS14
eastcoastS14's Avatar
my guess is the same as whoever gets it right
so wheres my $5?
eastcoastS14 is offline   Reply With Quote
Old 04-21-2008, 10:11 PM   #7
!Zar!
!Zar!'s Avatar
The $5 is mine. =)
Old 04-21-2008, 10:20 PM   #8
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
i had that problem before. i cleaned and put new gasket on my iacv and also my o-ring of two of my injectors was bad - after replacing these as well my car stop idling funny and stop sounding like a subaru.
Modrified is offline   Reply With Quote
Old 04-21-2008, 10:21 PM   #9
180sx_Drifter
haha too bad i was first!
Old 04-21-2008, 10:23 PM   #10
aznpoopy
aznpoopy's Avatar
even easier way to check is simply pop open the oil filler cap and take a sniff. if its flooding you'll know right away.
wouldn't drive it like that. my guess is oil + gas with the consistency of water doesn't really lube engine parts all that well
aznpoopy is offline   Reply With Quote
Old 04-21-2008, 10:26 PM   #11
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
Replace your injector seals.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 04-21-2008, 10:33 PM   #12
Tearlessj
Tearlessj's Avatar
Im ganna try all of the above tomorrow. Ill let you guys know.
Nagasaki Motors
Old 04-22-2008, 12:28 AM   #13
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
do your upper and lower injector seals/o-rings. Be sure to put LOTS of lub on them. Something other then egine oil if possible. Just do all 4 injectors. Doing them 1 at a time well just make you more and more pissed when the next one goes.
If you have a really rought Idle do a cylinder balance test. Pull 1 plug wire at a time, if you notice a no change in the idle, that cylinder is missing/not doing enought work. If the car pretty much dies that cylinder is good.
KA-T_240 is offline   Reply With Quote
Old 04-23-2008, 12:47 PM   #14
!Zar!
!Zar!'s Avatar
Where is my $5?!
Old 04-23-2008, 12:48 PM   #15
Dousan_PG
Dousan_PG's Avatar
u got scammed.
these bitches never pay up on the 5
give zar the 5 bucks or be neg repped to hell!!
yes, im serious.
Aaron
Pink GodziRa
Old 04-23-2008, 12:53 PM   #16
!Zar!
!Zar!'s Avatar
Yeah.
For real.
I'm about to neg rep your ass.
That $5 could get me a couple laps around the track!
WTF!
Old 04-23-2008, 12:54 PM   #17
Dousan_PG
Dousan_PG's Avatar
thats a full meal at wendys!!
2 5 piece chicken nuggets w/ bbq sauce
1 jr bacon
1 lemonaide w/ free refills!!
Aaron
Pink GodziRa
Old 04-23-2008, 12:56 PM   #18
!Zar!
!Zar!'s Avatar
That's like almost fifty packs of kool aid!
You were neg repped.
Sorry.
I'm serious when it comes to my money.
Just ask my hoes.
They know what's up.
Old 04-23-2008, 02:19 PM   #19
ClutchKickThatBitch
ClutchKickThatBitch's Avatar
ClutchKickThatBitch is on the path to ruinClutchKickThatBitch is on the path to ruinClutchKickThatBitch is on the path to ruin
Sorry.
Just ask my hoes.
this dude is F**KING FUNNY LOL...+1
ClutchKickThatBitch is offline   Reply With Quote
Old 04-23-2008, 03:09 PM   #20
Tearlessj
Tearlessj's Avatar
Sorry man, my grandpa was in the Hospice program and he was acting up so I had to go to the hospital and stay the night there with him. I've been driving my dads car around. I have managed to buy the throttle cleaner and injector o-rings though. I will get to it ASAP. People are starting to come visit my gramps at the hospital so I have to take care of out town family tonight. I can provide proof if you want.
Nagasaki Motors
Old 04-23-2008, 03:16 PM   #21
invisibleman
invisibleman is making his/her stupidity well-knowninvisibleman is making his/her stupidity well-knowninvisibleman is making his/her stupidity well-knowninvisibleman is making his/her stupidity well-knowninvisibleman is making his/her stupidity well-known
i had a similar problem, especially with the leaky injector. Lots of lucas fuel cleaner fixed it. the second s13 i had with that problem i had to take out the 2 injectors that were leaky and clean it for it to stop.
invisibleman is offline   Reply With Quote
Old 04-23-2008, 03:21 PM   #22
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
I bet you have a short to ground in your knock sensor wire, meaning the shielding has broke threw and grounded out your signal wire. Best bet it to check voltage at teh ECU with teh key on you should see 2.5 volts anymore or less indicates a problem, must likely you will see less than 2.5 volts for a short to ground.
Your code 45 is most likely do to your problem with the knock sesnor as I just described above.
