Old 04-25-2008, 10:38 PM   #1
mymymys13
mymymys13 is making his/her stupidity well-knownmymymys13 is making his/her stupidity well-knownmymymys13 is making his/her stupidity well-knownmymymys13 is making his/her stupidity well-known
is this normal?
so i took on my first project on my car. (connecting electric fans)
so i eleminated my old fans and got my hands on some altima fans. i put them on and connected them to my fuel pump fuse. ive noticed whenever i turn my car off now theres a lag (it doesnt turn off right away, maybe 2 seconds later)
is that bad?
sorry ima noob
mymymys13 is offline   Reply With Quote
Old 04-25-2008, 10:57 PM   #2
SC_S13
SC_S13's Avatar
SC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to all
maybe connecting them to the fuel pump fuse is causing the delay? is there any other spot to splice them?
SC_S13 is offline   Reply With Quote
Old 04-26-2008, 10:25 AM   #3
mymymys13
um im not sure. my friend said that itll be okay but than i feel as if the job was half ass done because i know youre supposed to connect them else where. he told me thats the easy way to connect them
Old 04-26-2008, 10:35 AM   #4
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
thats a horrible plcae to power ur fans from...the s chassis fuel pump is already disgustingly under powered
do it right...go get yourself a relay setup and run a direct tap from the battery to your fans...run a switch to the inside of your car and turn them on and off whenever you drive the car...running a proper and constant 12 volt connection to them will ensure proper RPMs from the fans
running your power source from your fuel pump is asking for problems...the S chassis fuel pump has such tiny wiring runing to it that it struggles to carry a proper 12 volt current back to it...youll find this out when you go a run a larger fuel pump (especially a fuel pump that handles more than 500hp like a denso supra pump)...should you encounter any kind of power spike in your motor...you start blowing fuel pump fuses like crazy keeping your fans wired like that
btw...why are you running altima fans??? the best fan setup by far for the S chassis is the clutch fan and shroud (youll find this out REAL easy if you go somewhere thats super hot...like vegas or phoenix)...the altima fans are decent...but still dont draw what the clutch fan and shroud do...if you want an electric fan...just use the one that came with the 91-94 S13s...run a relay and switch for that and turn it on during track use WITH the clutch
