Old 12-20-2001, 06:44 PM   #1
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
Hey what's up i am gonna put rims on my 91 s13 soon, i want to put on 18's but i was wondering if they would fit fine?? Anyone with rims know how big can fit? Or if you have 18's how are they doing?
hookedup240 is offline   Reply With Quote
Old 12-20-2001, 10:27 PM   #2
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
18's will fit, but they are going to slow you down quite a bit, not to mention punch a hole in your wallet. I'm planning on 16's or 17's I really want 16's, but I don't know if I want to get them in case I do a brake upgrade.
As far as width goes, I believe it's 10" rear, and 9" up front.
transient is offline   Reply With Quote
Old 12-20-2001, 10:28 PM   #3
Guest
Posts: n/a
how would the 18's slow u down?
Old 12-20-2001, 10:32 PM   #4
DSC
New Title
DSC is an unknown quantity at this point
you've got more to move with 18's
DSC is offline   Reply With Quote
Old 12-20-2001, 10:33 PM   #5
Guest
Posts: n/a
but if they weigh less wouldnt that balance it out? so if i got 12's my car would be faster? LoL
Old 12-20-2001, 11:12 PM   #6
DSC
New Title
There's more to it than just weight but I dont' know enough about it to give you a good answer so I'm not even gona try...anybody else care to explain? Hehe, our cars would look really funny with 12's.
Old 12-20-2001, 11:41 PM   #7
Kefabi
Kefabi is an unknown quantity at this point
Send a message via ICQ to Kefabi
Why do 15's go faster than 18's? Here's the reason.
In a first semester calculus-based physics class, you learn that a bowling ball will ALWAYS roll down a hill faster than a basketball. ####, a foam nerf ball will roll down a hill faster in a vacuum (environment with no air friction). The reason is a bit simple.
For a basketball to roll around once, all it's mass has to roll all the way around the outside of the ball.
A bowling ball has much of it's mass towards the center. The mass at the center only has to roll around a little bit, while the mass at the outside also must roll all the way around the ball.
The difference is, ALL the basketball's mass must roll ALL the way around, where only a LITTLE bit of the bowling ball's mass rolls ALL the way around.
Basically, the rule is the more mass concentrated around the center of a round object, the faster it accererates down a hill.
Vica Versa, the more mass concentrated at the outside, the slower it'll accelerate since it has to move ALL it's mass a long way.
Now take this to tires. 15 inches have move mass in the center, a lot of air around the outside.
18 inches has a LOT more mass close to the outside, and that mass towards the outside has to move farther to roll around once. So to get the same forward speed as the 15 inches, the 18 inches needs more force to get the mass on the outside accelerating as fast as the 15 inches.
I hope that makes sense (Though I know it's a bit lengthy). If you have more questions, need something cleared up, post a response!
Kefabi is offline   Reply With Quote
Old 12-21-2001, 09:57 AM   #8
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
the simplified answer is:
unless you spend a ton of $$$, your 18s will be heavy as ####.  good luck finding 18s under 22 lbs.  if you do, theyll be 500 per wheel.  15s, no problems.  also, tires for 18s cost twice as much as tires for 17s.
so, if you want big wheels, max out at 17s.
vancouvers14 is offline   Reply With Quote
Old 12-22-2001, 04:41 PM   #9
hookedup240
Ok thanks for those who told me what would fit. I know how much rims cost i already know which ones i want i wasn't worrying about that, And whoever said rims are 500 each for nice 18 where the #### do you live/shop and tires arent' even that much i am getting Konig Verdicts for 177 each(18's) and new falken tires for 150 each so i dont' know what you are smoking
