Old 04-30-2008, 08:43 PM   #1
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
A/C wiring for a S14 SR in a S13?
I have tried searching with no luck but I was trying to see if this is correct from what I've found in the FSMs. I have pin 25 (green/yellow) from F1 (s14 interior plug) going to green/yellow on F1 (s13 interior plug) then extended to green/yellow on F9 (s13 harness under the hood by the battery) for the relay. For the thermal control amp (AC switch) I have pin 17 (red) from F1 (s14 interior plug) to the blue/green on F1 (s13 interior plug) then extended to blue/green on F9 (s13 harness under the hood by the battery). Is this correct? I was just looking for verification from anybody that may be able to help. Thanks!
C. Anderson is offline   Reply With Quote
Old 05-02-2008, 08:08 AM   #2
C. Anderson
Can anybody comfirm?
Old 05-02-2008, 11:44 PM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
run the blue/green stripe on your s13's dash plug behind the glove box to your green/yellow on your s13's brownish/red plug on the passenger side fender where the battery goes
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 05-03-2008, 06:48 AM   #4
C. Anderson
Thanks! I'll check that out.
Old 05-03-2008, 07:05 AM   #5
juls213
juls213 is making a name for him/her selfjuls213 is making a name for him/her selfjuls213 is making a name for him/her self
What kind of compressor and bracket are you using?
I have an s14 with s13redtop. Can i use the sr bracket with s14kade compressor? Guys I need AC lol
juls213 is offline   Reply With Quote
Old 05-03-2008, 08:52 AM   #6
Z U L8R
Z U L8R's Avatar
juls it'd probably be the easiest thing to use the red top sr compressor and bracket and get the ends of the high and low pressure hoses fabricated. gl
Dave =]
