Old 11-20-2002, 01:58 AM   #1
019
019's Avatar
019 is an unknown quantity at this point
Send a message via AIM to 019
ok, this is weird...  my car was running fine until a couple days ago, i put her in reverse, then while going through neutral to get to first gear, my car stalled.  i didn't think anything of it then, but it's happening more and more frequently... i really don't know what's up...
i have a 96, btw.
019 is offline   Reply With Quote
Old 11-20-2002, 09:30 AM   #2
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
do you have intake?? make sure you check that its in there tight.... cause mine was lose and my car did the same thing...
SR240DET is offline   Reply With Quote
Old 11-21-2002, 09:54 AM   #3
019
019's Avatar
naw, all i have is the stock intake.  any other ideas on what could be wrong?
Old 11-21-2002, 03:02 PM   #4
AKADriver
AKADriver's Avatar
Same thing...  vacuum leaks.
Start with the numerous valves at the back of the intake, they can get stuck and cause problems.  Also as SR240DET said check the intake tubing for loose connections or cracks.
