Old 05-01-2008, 10:29 PM   #1
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Question about Nismo Extended Studs
I did search this but couldn't find an answer to my particular question.
From what I could find stock studs are between 40-42mm long. Basically does anyone run 60mm Nismo studs with 20mm slip on spacers? I have some Ichiba 20mm spacers and am not particularly happy with the quality of the studs themselves (I actually had two lug nuts seize to the studs and had to break them off). I didn't measure them before I put them on, but they are ~20mm bigger then the OEM ones.
It would be a lot more cost efficient to buy some Nismo 60mm studs then to rip off these spacers and buy stock studs, then 20mm bolt on spacers.
Again, my question in the short version is: Can I safely run 20mm slip on spacers with 60mm Nismo studs?
Thank you.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
