Old 11-21-2002, 01:08 AM   #1
DarkRaptor42
DarkRaptor42 is an unknown quantity at this point
I need an LSD and saw the s15 LSDs on Ebay. What I want to know is if that will just drop into my S13 pumpkin or what Id have to do to make it fit. My cars like a week away from going in to get painted so im picking up parts now for when it gets out. As always your replies are appreciated.
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
DarkRaptor42 is offline   Reply With Quote
Old 11-21-2002, 08:50 AM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
It depends on what kind of diffs you are getting
> and starting with.
> For instance, the stock open diff uses two identical
> output flanges,
> while the VLSD unit uses a shorter one on one side.
> Some aftermarket
> diffs are made to drop into the open diff, while
> others the vlsd.
>  As for the helical unit from an S15, in short, it
> won't work.
> (guessing you are eyeballing the ones on ebay) The
> S13/S14 output
> flange's spline shafts are a smaller diameter. S15
> output flanges
> (which aren't even included) won't bolt to your
> axles anyway. I'm
> currently trying to verify the possibility of using
> old Skyline
> output shafts which are relatively cheap/easy to
> get, I just can't
> get a straight answer. Failing that, I'll probably
> end up buying S15
> flanges (cha-ching) and machining/welding them.
>  You'll need something to smear on the ring gear to
> make sure it's
> meshing correctly (I used spray paint but don't
> recommend it), and
> if it doesn't, you'll need a thicker or thinner
> shim.
this lesson brought to you by Tony from atlanta after his research into the matter <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 11-21-2002, 05:30 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Dont use the spray paint.....you can buy a yellow grease tube from the GM parts department. &nbsp;That works well...if you know how to interpret the lash marks the pinon gear leaves on the diff gears. &nbsp;My advice to you is to take the pumpkin and the LSD into a tranny/gear shop....and have them shim match if for you.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 11-22-2002, 12:20 AM   #4
tys240
tys240 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Steeles @ Nov. 21 2002,09:50)</td></tr><tr><td id="QUOTE">
won't work. (guessing you are eyeballing the ones on ebay) The S13/S14 output flange's spline shafts are a smaller diameter. S15 &nbsp;output flanges (which aren't even included) won't bolt to your axles anyway. I'm currently trying to verify the possibility of using old Skyline output shafts which are relatively cheap/easy to get, I just can't get a straight answer. Failing that, I'll probably end up buying S15
make sure it's meshing correctly (I used spray paint but don't
recommend it), and if it doesn't, you'll need a thicker or thinner shim.
this lesson brought to you by Tony from atlanta after his research into the matter <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
Actually,
The S15 pumpkin WILL bolt onto the S14 axles--they're identical.
I wouldn't get one of these HLDs on eBay unless it included the pumkin/casing--they never do...
-ty
tys240 is offline   Reply With Quote
