Old 05-06-2008, 08:52 PM   #1
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
elbow not bolting up to turbo
ok guys, i just got a gt2871 today i'm trying to bolt up the stock t25 elbow to the t28 and its one of the bolts is not aligning with the hole to slide the elbow on properly. am i supposed to use the t28 elbow? thought i could use the t25. should i redrill the hole on the elbow to make it slightly bigger? just about 2mm will do. lmk thanks
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
