Old 11-25-2002, 02:35 PM   #1
shawn_16
shawn_16 is an unknown quantity at this point
got some 91 cams coming in to put in my 95 and is there anything "special" i have to do to put them in?
is the sohc flywheel swapable w/the dohc engine (i heard it lighter) because i'm to go check out some junkyards
shawn_16 is offline   Reply With Quote
Old 11-25-2002, 05:25 PM   #2
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
Oh so you are the guy who beat me at the last second on that set &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'>
Anyways, there is nothing extreme as long as you keep track of what you took off and mark the position of cams and chain before you take anything off. If u mess those up, you'll have reaaaaaaallly hard time aligning them back again.
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 11-25-2002, 07:03 PM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
You will need a machine shop to re-pin the cams to match your engine. &nbsp;
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 11-25-2002, 07:12 PM   #4
Kreator
Kreator's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Jeff240sx @ Nov. 25 2002,8:03)</td></tr><tr><td id="QUOTE">You will need a machine shop to re-pin the cams to match your engine. &nbsp;
-Jeff</td></tr></table><span id='postcolor'>
Eh? You have to do that? They aren't bolt on? Hmmm i always thought they were plug in and go.... any clue on how much it'll cost to repin? I'm getting some myself kinda soon...
Old 11-26-2002, 08:51 AM   #5
Grandpa
Grandpa is an unknown quantity at this point
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'> You do not need to repin the '91 cams to work in your '95. The only reason you would need to repin the cams, is if you wish to use an exhaust cam for your intake cam, ie. you want 248/248 cams instead of 240/248.
I did the cam swap this past weekend, and it was fairly straight forward. An FSM helps a bunch, and the only other thing I needed was a tube of permatex ultra-black liquid gasket.
Just make sure the engine is at TDC, and you'll be all good.
The FSM recommends re-shimming the cams, but I did not. Others have not as well and haven't had any problems.
BTW, you'll like the swap. My car pulls good now. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
-john
edit: grammar
Grandpa is offline   Reply With Quote
Old 11-26-2002, 11:03 AM   #6
shawn_16
i did some research and found your post on 240sx.org forums grandpa
anybody got an answer for my flywheel question?
kreator - sorry man, the day before someone outbid me on an injen intake and i'm not about to leave ebay empty handed
Old 11-26-2002, 11:40 AM   #7
Jeff240sx
I hate you too...
Jeff240sx's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Grandpa @ Nov. 26 2002,10:51)</td></tr><tr><td id="QUOTE">The only reason you would need to repin the cams, is if you wish to use an exhaust cam for your intake cam, ie. you want 248/248 cams instead of 240/248.</td></tr></table><span id='postcolor'>
Yea. &nbsp;That's what most people do when they buy 2 cams. &nbsp;They swap them both.
Sorry I made you guys think you had to repin both cams. &nbsp;I meant the exhaust cam.
Kreator- I really don't know a cost on that, but I doubt it is expensive. &nbsp;All a machine shop needs to do is drill a hole and insert a dowell.
-Jeff
Whatup?
