Old 05-15-2008, 08:28 PM   #1
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
HELP! Oil pick-up/no pressure
Alright I need some help. I have a redtop SR. I just changed the stock oil pan to a Greddy pan. That is the only change. Pulled the old pan, used a good razor blade cleaned all the old silicone off, let all the oil drip off, cleaned it real good, used ultra black rtv, installed new pan. I let it sit for about a day so the rtv would set up nice, and filled it up with oil. Let it sit for a couple hours just to make sure it sealed up nice, good to go, no leaks. Well I started up the car tonight, and as soon as I did the oil pressure light was on! WTF, I shut it down right away, went and double checked the oil level, still good. WTF? Any thoughts? I never had any pressure problems before. What holds the pick-up on, is there a chance that it dropped down? I made sure to clean the screen out and make sure that none of the old silicone was in there before I put it back together. What could be the problem? I'm gonna have to pull the pan again tomorrow to check, but thought I'd try to get some advise or push in the right direction before I just start tearing things apart. HELP HELP HELP.
I need to get this fixed in the next day or 2 because I have an event coming up on sunday that I already paid for and is non-refundable.
Kouki is offline   Reply With Quote
